Datasheet Texas Instruments SN74ALVC164245-W — Даташит
Серия | SN74ALVC164245 |
Модель | SN74ALVC164245-W |
16-битный приемопередатчик со сдвигом уровня от 2,5 до 3,3 В/3,3 до 5 В с выходами с тремя состояниями 0-WAFERSALE
SN74ALVC164245 16-Bit 2.5-V to 3.3-V or 3.3-V to 5-V Level-Shifting Transceiver With 3-State Outputs datasheet
PDF, 1.1 Мб, Версия: Q, Файл опубликован: 27 сен 2016
Купить SN74ALVC164245 на РадиоЛоцман.Цены — от 14 до 376 ₽ 49 предложений от 28 поставщиков TRANSCEIVER, LEVEL SHIFTER, SMD; Logic IC Function:Level Shifting Transceiver; Logic IC Family:LVC; Logic IC Base Number:74164245; Transceivers, No. of:16; Interface Type:LVTTL;... | |||
SN74ALVC164245DGGR Texas Instruments | 14 ₽ | ||
74LVC164245DGG (SN74ALVC164245DGG) | 42 ₽ | ||
SN74ALVC164245DLR | 232 ₽ | ||
SN74ALVC164245DGGT Texas Instruments | от 371 ₽ |
Package Type | YS |
Approx. Price (US$) | 0.87 | 1ku |
Bits(#) | 16 |
ICCA Static Current(mA) | 0.04 |
ICCB Static Current(mA) | 0.04 |
Package Group | WAFERSALE |
Package Size: mm2:W x L (PKG) | 56BGA MICROSTAR JUNIOR: 32 mm2: 4.5 x 7(BGA MICROSTAR JUNIOR) 54BGA MICROSTAR JUNIOR: 44 mm2: 5.5 x 8(BGA MICROSTAR JUNIOR) 48TSSOP: 101 mm2: 8.1 x 12.5(TSSOP) 48SSOP: 164 mm2: 10.35 x 15.88(SSOP) |
Rating | Catalog |
Special Features | N/A |
VCCA(Max)(V) | 3.3 |
VCCA(Min)(V) | 2.5 |
VCCB(Max)(V) | 5 |
VCCB(Min)(V) | 3.3 |
RoHS | Не совместим |
- Benefits & Issues of Migrating 5-V and 3.3-V Logic to Lower-Voltage Supplies (Rev. A)PDF, 154 Кб, Версия: A, Файл опубликован: 8 сен 1999
In the last few years the trend toward reducing supply voltage (VCC) has continued as reflected in an additional specification of 2.5-V VCC for the AVC ALVT ALVC LVC LV and the CBTLV families.In this application report the different logic levels at VCC of 5 V 3.3 V 2.5 V and 1.8 V are compared. Within the report the possibilities for migration from 5-V logic and 3.3-V logic families - Understanding Advanced Bus-Interface Products Design GuidePDF, 253 Кб, Файл опубликован: 1 май 1996
- TI SN74ALVC16835 Component Specification Analysis for PC100PDF, 43 Кб, Файл опубликован: 3 авг 1998
The PC100 standard establishes design parameters for the PC SDRAM DIMM that is designed to operate at 100 MHz. The 168-pin, 8-byte, registered SDRAM DIMM is a JEDEC-defined device (JC-42.5-96-146A). Some of the defined signal paths include data signals, address signals, and control signals. This application report discusses the SN74ALVC16835 18-bit universal bus driver that is available from T - Logic Solutions for PC-100 SDRAM Registered DIMMs (Rev. A)PDF, 96 Кб, Версия: A, Файл опубликован: 13 май 1998
Design of high-performance personal computer (PC) systems that are capable of meeting the needs imposed by modern operating systems and software includes the use of large banks of SDRAMs on DIMMs (see Figure 1).To meet the demands of stable functionality over the broad spectrum of operating environments, meet system timing needs, and to support data integrity, the loads presented by the large - 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
Серия: SN74ALVC164245 (15)
- Semiconductors > Logic > Voltage Level Translation > Application Specific Voltage Translation
SN74ALVC164245W, SN74ALVC164245 W
