Datasheet Texas Instruments TAS5713PHPR — Даташит
Серия | TAS5713 |
Модель | TAS5713PHPR |
Стереоусилитель звука I2S мощностью 25 Вт с эквалайзером динамика и 2-полосным DRC 48-HTQFP от 0 до 85
TAS5713 25-W Digital Audio Power Amplifier With EQ and DRC datasheet
PDF, 2.2 Мб, Версия: A, Файл опубликован: 23 авг 2010
Купить TAS5713PHPR на РадиоЛоцман.Цены — от 172 до 612 ₽ 14 предложений от 11 поставщиков 25-W Stereo I2S Audio Amplifier with Speaker EQ and 2-Band DRC 48-HTQFP 0 to 85 | |||
TAS5713PHPR Texas Instruments | 172 ₽ | ||
TAS5713PHPR Texas Instruments | 235 ₽ | ||
TAS5713PHPR Texas Instruments | по запросу | ||
Pin | 48 |
Package Type | PHP |
Industry STD Term | HTQFP |
JEDEC Code | S-PQFP-G |
Package QTY | 1000 |
Carrier | LARGE T&R |
Маркировка | TAS5713 |
Width (мм) | 7 |
Length (мм) | 7 |
Thickness (мм) | 1 |
Pitch (мм) | .5 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Analog Supply (V) | 3.6 Min |
Audio Input Type | Digital |
Closed/Open Loop | Open |
Control Interface | Software |
Рабочий диапазон температур | от 0 до 85 C |
Package Group | HTQFP |
Package Size: mm2:W x L | 48HTQFP: 81 mm2: 9 x 9(HTQFP) PKG |
Power Stage Supply(Max) | 26 В |
Power Stage Supply(Min) | 8 В |
Power to Bridge Tied Load(Max) | 21.5 W |
Power to Parallel Bridge Tied Load(Max) | 41.5 W |
Rating | Catalog |
Sampling Rate(Max) | 48 kHz |
Sampling Rate(Min) | 8 kHz |
Speaker Channels | 2 Max |
Supported Bridge Tied Load(Min) | 4 Ohms |
- Evaluation Modules & Boards: TAS5713PHPEVM
TAS5713PHP Evaluation Module
- TAS57xx Dynamic Range ControlPDF, 324 Кб, Файл опубликован: 18 июн 2010
This application report provides background information, general equations, and instructions for proper use of the Texas Instruments TAS57xx series Dynamic Range Control (DRC). Topics include I2C configuration, single-band and dual-band DRC, coefficient computation, device offerings, and user interface configuration. - AN-1737 Managing EMI in Class D Audio Applications (Rev. A)PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit. - Using Thermal Calculation Tools for Analog ComponentsPDF, 1.1 Мб, Файл опубликован: 2 сен 2010
This document provides general guidance on the use of toolsand calculations for thermal estimates of component operating temperatures for analog devices. Of particularfocus are components with direct thermal paths to the PCB which is common for components which need a low thermal resistance to manage the dissipated power. This document provides practical considerations for estimation of o - AN-1849 An Audio Amplifier Power Supply Design (Rev. B)PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs. - Guidelines for Measuring Audio Power Amplifier PerformancePDF, 765 Кб, Файл опубликован: 30 окт 2001
This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
Серия: TAS5713 (1)
- TAS5713PHPR
- Semiconductors > Audio > Mid-Power Audio Amplifiers (10-50W) > Digital I2S Input Class-D
