Datasheet Texas Instruments SN74LVCH16245AZRDR — Даташит
Серия | SN74LVCH16245A |
Модель | SN74LVCH16245AZRDR |
16-битный шинный трансивер с выходами с 3 состояниями 54 BGA MICROSTAR JUNIOR от -40 до 85
SN74LVCH16245A 16-bit Bus Transceiver With 3-state Outputs datasheet
PDF, 1.0 Мб, Версия: C, Файл опубликован: 7 ноя 2013
Купить SN74LVCH16245AZRDR на РадиоЛоцман.Цены — от 74 до 119 ₽ 10 предложений от 10 поставщиков Transceiver, Non-Inverting 2 Element 8 Bit per Element 3-State Output 54-BGA Microstar Junior (8x5.5) | |||
SN74LVCH16245AZRDR Texas Instruments | 74 ₽ | ||
SN74LVCH16245AZRDR Texas Instruments | 78 ₽ | ||
SN74LVCH16245AZRDR Texas Instruments | 117 ₽ | ||
SN74LVCH16245AZRDR Texas Instruments | по запросу |
Pin | 54 |
Package Type | ZRD |
Industry STD Term | BGA MICROSTAR JUNIOR |
JEDEC Code | R-PBGA-N |
Package QTY | 1000 |
Carrier | LARGE T&R |
Маркировка | LDH245A |
Width (мм) | 5.5 |
Length (мм) | 8 |
Thickness (мм) | .8 |
Pitch (мм) | .8 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Bits | 16 |
F @ Nom Voltage(Max) | 100 Mhz |
ICC @ Nom Voltage(Max) | 0.02 мА |
Рабочий диапазон температур | от -40 до 125,-40 до 85 C |
Output Drive (IOL/IOH)(Max) | -24/24 мА |
Package Group | BGA MICROSTAR JUNIOR |
Package Size: mm2:W x L | 56BGA MICROSTAR JUNIOR: 32 mm2: 4.5 x 7(BGA MICROSTAR JUNIOR) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | LVC |
VCC(Max) | 3.6 В |
VCC(Min) | 1.65 В |
Voltage(Nom) | 1.8,2.5,2.7,3.3 В |
tpd @ Nom Voltage(Max) | 7.1,4.5,4.7,4 нс |
- Bus-Hold CircuitPDF, 418 Кб, Файл опубликован: 5 фев 2001
When designing systems that include CMOS devices, designers must pay special attention to the operating condition in which all of the bus drivers are in an inactive, high-impedance condition (3-state). Unless special measures are taken, this condition can lead to undefined levels and, thus, to a significant increase in the device?s power dissipation. In extreme cases, this leads to oscillation of
Серия: SN74LVCH16245A (11)
- Semiconductors > Logic > Buffer/Driver/Transceiver > Standard Transceiver
