Datasheet Texas Instruments LMH6646MMX/NOPB — Даташит
Серия | LMH6646 |
Модель | LMH6646MMX/NOPB |
2.7V, 650ВµA, 55MHz Rail-to-Rail Input and Output Amplifiers with Shutdown Option 8-VSSOP -40 to 85
LMH664x 2.7 V, 650 uA, 55 MHz, Rail-to-Rail I/O Amplifiers w/Shutdown Option datasheet
PDF, 1.7 Мб, Версия: D, Файл опубликован: 25 ноя 2014
Купить LMH6646MMX/NOPB на РадиоЛоцман.Цены — от 80 до 381 ₽ 14 предложений от 11 поставщиков 2.7V, 650μA, 55MHz Rail-to-Rail Input and Output Amplifiers with Shutdown Option 8-VSSOP -40℃ to 85℃ | |||
LMH6646MMX/NOPB Texas Instruments | 80 ₽ | ||
LMH6646MMX/NOPB National Semiconductor | 89 ₽ | ||
LMH6646MMX/NOPB Texas Instruments | 109 ₽ | ||
LMH6646MMX/NOPB Texas Instruments | по запросу |
Pin | 8 |
Package Type | DGK |
Industry STD Term | VSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 3500 |
Carrier | LARGE T&R |
Маркировка | A70A |
Width (мм) | 3 |
Length (мм) | 3 |
Thickness (мм) | .97 |
Pitch (мм) | .65 |
Max Height (мм) | 1.07 |
Mechanical Data | Скачать |
2nd Harmonic | 62 dBc |
3rd Harmonic | 72 dBc |
@ MHz | 1 |
Acl, min spec gain | 1 V/V |
Additional Features | N/A |
Архитектура | Bipolar,Voltage FB |
BW @ Acl | 55 МГц |
CMRR(Min) | 60 дБ |
CMRR(Typ) | 84 дБ |
GBW(Typ) | 55 МГц |
Input Bias Current(Max) | 2000000 pA |
Iq per channel(Max) | 1.6 мА |
Iq per channel(Typ) | 0.725 мА |
Количество каналов | 2 |
Offset Drift(Typ) | 5 uV/C |
Output Current(Typ) | 20 мА |
Package Group | VSSOP |
Package Size: mm2:W x L | 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG |
Rail-to-Rail | In,Out |
Rating | Catalog |
Slew Rate(Typ) | 22 V/us |
Total Supply Voltage(Max) | 12 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 2.5 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 17 нВ/rtГц |
Vn at Flatband(Typ) | 17 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 3 мВ |
- Evaluation Modules & Boards: LMH730123
Evaluation Board for High-Speed Dual Op Amp in the 8-Pin MSOP Package
- AN-1515 A Comprehensive Study of the Howland Current Pump (Rev. A)PDF, 165 Кб, Версия: A, Файл опубликован: 26 апр 2013
It is well known to analog experts that you can use the positive and negative inputs of an operationalamplifier to make a high-impedance current source (current pump) using a conventional operationalamplifier (op amp). This basic circuit can put out both + and - output current (or zero current) into variousloads. The theory is simple. But the practical problems involved are not so simple or
Серия: LMH6646 (6)
- LMH6646 MDC LMH6646MA/NOPB LMH6646MAX/NOPB LMH6646MM LMH6646MM/NOPB LMH6646MMX/NOPB
- Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > High-Speed Op Amps (>=50MHz)
