Datasheet Texas Instruments SN74AHCU04DBR — Даташит
Серия | SN74AHCU04 |
Модель | SN74AHCU04DBR |
Шестигранные инверторы 14-SSOP от -40 до 85
SN54AHCU04, SN74AHCU04 datasheet
PDF, 967 Кб, Версия: K, Файл опубликован: 9 июл 2003
Купить SN74AHCU04DBR на РадиоЛоцман.Цены — от 3.77 до 23 ₽ 19 предложений от 12 поставщиков Микросхема: IC INVERTER 6CH 1-INP 14SSOP | |||
SN74AHCU04DBR Texas Instruments | от 3.77 ₽ | ||
SN74AHCU04DBR Texas Instruments | 8.22 ₽ | ||
SN74AHCU04DBR Texas Instruments | по запросу | ||
Pin | 14 |
Package Type | DB |
Industry STD Term | SSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | HD04 |
Width (мм) | 5.3 |
Length (мм) | 6.2 |
Thickness (мм) | 1.95 |
Pitch (мм) | .65 |
Max Height (мм) | 2 |
Mechanical Data | Скачать |
Bits | 6 |
F @ Nom Voltage(Max) | 70 Mhz |
ICC @ Nom Voltage(Max) | 0.02 мА |
Output Drive (IOL/IOH)(Max) | -50/50 мА |
Package Group | SSOP |
Package Size: mm2:W x L | 14SSOP: 48 mm2: 7.8 x 6.2(SSOP) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | AHC |
VCC(Max) | 5.5 В |
VCC(Min) | 2 В |
Voltage(Nom) | 3.3,5 В |
tpd @ Nom Voltage(Max) | 12,8 нс |
- Benefits & Issues of Migrating 5-V and 3.3-V Logic to Lower-Voltage Supplies (Rev. A)PDF, 154 Кб, Версия: A, Файл опубликован: 8 сен 1999
In the last few years the trend toward reducing supply voltage (VCC) has continued as reflected in an additional specification of 2.5-V VCC for the AVC ALVT ALVC LVC LV and the CBTLV families.In this application report the different logic levels at VCC of 5 V 3.3 V 2.5 V and 1.8 V are compared. Within the report the possibilities for migration from 5-V logic and 3.3-V logic families
Серия: SN74AHCU04 (17)
- Semiconductors > Logic > Buffer/Driver/Transceiver > Inverting Buffer/Driver
