Datasheet Texas Instruments SN74LVC1G19DBVR — Даташит
Серия | SN74LVC1G19 |
Модель | SN74LVC1G19DBVR |
Декодер/демультиплексор 1 из 2 6-SOT-23 от -40 до 85
SN74LVC1G19 1-of-2 Decoder and Demultiplexer datasheet
PDF, 1.3 Мб, Версия: G, Файл опубликован: 31 авг 2015
Купить SN74LVC1G19DBVR на РадиоЛоцман.Цены — от 1.88 до 28 ₽ 40 предложений от 19 поставщиков IC: цифровая; декодер,демультиплексор; Ch: 1; IN: 2; CMOS; SMD; SOT23 | |||
SN74LVC1G19DBVR Texas Instruments | 1.88 ₽ | ||
SN74LVC1G19DBVR Texas Instruments | 5.41 ₽ | ||
SN74LVC1G19DBVR Texas Instruments | 6.96 ₽ | ||
SN74LVC1G19DBVR Texas Instruments | от 28 ₽ |
Pin | 6 | 6 | 6 |
Package Type | DBV | DBV | DBV |
Industry STD Term | SOT-23 | SOT-23 | SOT-23 |
JEDEC Code | R-PDSO-G | R-PDSO-G | R-PDSO-G |
Package QTY | 3000 | 3000 | 3000 |
Carrier | LARGE T&R | LARGE T&R | LARGE T&R |
Маркировка | C195 | C19R | C19K |
Width (мм) | 1.6 | 1.6 | 1.6 |
Length (мм) | 2.9 | 2.9 | 2.9 |
Thickness (мм) | 1.2 | 1.2 | 1.2 |
Pitch (мм) | .95 | .95 | .95 |
Max Height (мм) | 1.45 | 1.45 | 1.45 |
3-State Output | No |
Bits | 1 |
F @ Nom Voltage(Max) | 150 Mhz |
Gate Type | DECODER/DEMUX |
ICC @ Nom Voltage(Max) | 0.01 мА |
Logic | True |
Output Drive (IOL/IOH)(Max) | 32/-32 мА |
Package Group | SOT-23 |
Package Size: mm2:W x L | 6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Special Features | Ioff,down translation to Vcc,low power |
Sub-Family | Decoder/Encoder/Multiplexer |
Technology Family | LVC |
VCC(Max) | 5.5 В |
VCC(Min) | 1.65 В |
Voltage(Nom) | 1.8,2.5,3.3,5 В |
tpd @ Nom Voltage(Max) | 16.1,6.5,5.2,3.9 нс |
- LVC Characterization InformationPDF, 114 Кб, Файл опубликован: 1 дек 1996
This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices. - Use of the CMOS Unbuffered Inverter in Oscillator CircuitsPDF, 796 Кб, Файл опубликован: 6 ноя 2003
CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC1G19 (11)
- Semiconductors > Logic > Little Logic
