Datasheet Texas Instruments SN74LVC06AQPWRQ1 — Даташит
СерияSN74LVC06A-Q1
МодельSN74LVC06AQPWRQ1
Автомобильный каталог Шестигранные инверторные буферы/драйверы с выходами с открытым стоком 14-TSSOP от -40 до 125
Hex Inverter Buffer/Driver With Open-Drain Outputs datasheet
PDF, 782 Кб, Версия: B, Файл опубликован: 9 апр 2008
Inverter IC 6 Channel Open Drain 14-TSSOP
SN74LVC06AQPWRQ1
30 ₽
SN74LVC06AQPWRQ1
30 ₽
SN74LVC06AQPWRQ1
Flash-Turtle
SN74LVC06AQPWRQ1
Электромеханические реле Hongfa – надежность и качество 19 января 2023
Pin14
Package TypePW
Industry STD TermTSSOP
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Approx. Price (US$)0.15 | 1ku
Bits(#)6
F @ Nom Voltage(Max)(Mhz)100
ICC @ Nom Voltage(Max)(mA)0.01
Тип входаCMOS
TTL
Operating Temperature Range(C)-40 to 125
Output Drive (IOL/IOH)(Max)(mA)-24/24
Тип выходаCMOS
Package GroupTSSOP
Package Size: mm2:W x L (PKG)14TSSOP: 32 mm2: 6.4 x 5(TSSOP)
RatingAutomotive
Schmitt TriggerNo
Technology FamilyLVC
VCC(Max)(V)3.6
VCC(Min)(V)1.65
Voltage(Nom)(V)2.7
3.3
tpd @ Nom Voltage(Max)(ns)3.9
3.7
RoHSНе совместим
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Logic > Buffer/Driver/Transceiver > Inverting Buffer/Driver
На английском языке: Datasheet Texas Instruments SN74LVC06AQPWRQ1
Публикации по теме
