Datasheet Texas Instruments CD74HC126EE4 — Даташит
Серия | CD74HC126 |
Модель | CD74HC126EE4 |
Высокоскоростные КМОП-логические четырехъядерные буферы с выходами с 3 состояниями 14-PDIP от -55 до 125
CD54HC126, CD74HC126, CD54HCT126, CD74HCT126 datasheet
PDF, 933 Кб, Версия: C, Файл опубликован: 21 авг 2003
Купить CD74HC126EE4 на РадиоЛоцман.Цены — от 20 до 38 ₽ 8 предложений от 8 поставщиков new in stock for immediate delivery | |||
CD74HC126EE4 Texas Instruments | 20 ₽ | ||
CD74HC126EE4 Texas Instruments | 23 ₽ | ||
CD74HC126EE4 Texas Instruments | по запросу | ||
Pin | 14 |
Package Type | N |
Industry STD Term | PDIP |
JEDEC Code | R-PDIP-T |
Package QTY | 25 |
Carrier | TUBE |
Маркировка | CD74HC126E |
Width (мм) | 6.35 |
Length (мм) | 19.3 |
Thickness (мм) | 3.9 |
Pitch (мм) | 2.54 |
Max Height (мм) | 5.08 |
Mechanical Data | Скачать |
Bits | 4 |
F @ Nom Voltage(Max) | 28 Mhz |
ICC @ Nom Voltage(Max) | 0.08 мА |
Output Drive (IOL/IOH)(Max) | -6/6 мА |
Package Group | PDIP |
Package Size: mm2:W x L | See datasheet (PDIP) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | HC |
VCC(Max) | 6 В |
VCC(Min) | 2 В |
Voltage(Nom) | 6 В |
tpd @ Nom Voltage(Max) | 21 нс |
Бессвинцовая технология (Pb Free) | Да |
- Selecting the Right Texas Instruments Signal SwitchPDF, 769 Кб, Файл опубликован: 7 сен 2001
Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi - Using High Speed CMOS and Advanced CMOS in Systems With Multiple VccPDF, 43 Кб, Файл опубликован: 1 апр 1996
Though low power consumption is a feature of CMOS devices sometimes this feature does not meet a designer?s system power supply constraints. Therefore a partial system power down or multiple Vcc supplies are used to meet the needs of the system. This document shows electrostatic discharge protection circuits. It also provides circuit and bus driver examples of partial system power down and curren - SN54/74HCT CMOS Logic Family Applications and RestrictionsPDF, 102 Кб, Файл опубликован: 1 май 1996
Серия: CD74HC126 (6)
- CD74HC126E CD74HC126EE4 CD74HC126M CD74HC126M96 CD74HC126MG4 CD74HC126MT
- Semiconductors > Logic > Buffer/Driver/Transceiver > Non-Inverting Buffer/Driver
