Datasheet Texas Instruments UA741MFKB — Даташит
Серия | UA741 |
Модель | UA741MFKB |
Операционный усилитель общего назначения 20-LCCC от -55 до 125
µA741 General-Purpose Operational Amplifiers datasheet
PDF, 1.1 Мб, Версия: F, Файл опубликован: 2 май 2017
Купить UA741MFKB на РадиоЛоцман.Цены — от 342 до 412 ₽ 5 предложений от 5 поставщиков | |||
UA741MFKB Texas Instruments | 342 ₽ | ||
UA741MFKB Texas Instruments | 350 ₽ | ||
UA741MFKB Texas Instruments | 412 ₽ | ||
UA741MFKB | по запросу |
Pin | 20 |
Package Type | FK |
Industry STD Term | LCCC |
JEDEC Code | S-CQCC-N |
Width (мм) | 8.89 |
Length (мм) | 8.89 |
Thickness (мм) | 1.83 |
Pitch (мм) | 1.27 |
Max Height (мм) | 2.03 |
Mechanical Data | Скачать |
Рекомендуемая замена
Replacement | TLE2021MFKB |
Replacement Code | Q |
Additional Features | Vos Adj Pin |
Approx. Price (US$) | 0.11 | 1ku |
Архитектура | Bipolar |
CMRR(Min)(dB) | 70 |
CMRR(Typ)(dB) | 90 |
GBW(Typ)(MHz) | 1 |
Input Bias Current(Max)(pA) | 500000 |
Iq per channel(Max)(mA) | 2.8 |
Iq per channel(Typ)(mA) | 1.7 |
Number of Channels(#) | 1 |
Operating Temperature Range(C) | 0 to 70 |
Output Current(Typ)(mA) | 25 |
Package Group | PDIP SO SOIC |
Package Size: mm2:W x L (PKG) | See datasheet (PDIP) See datasheet (CDIP) |
Rail-to-Rail | No |
Rating | Catalog |
Slew Rate(Typ)(V/us) | 0.5 |
Total Supply Voltage(Max)(+5V=5, +/-5V=10) | 36 |
Total Supply Voltage(Min)(+5V=5, +/-5V=10) | 7 |
Vn at 1kHz(Typ)(nV/rtHz) | 20 |
Vos (Offset Voltage @ 25C)(Max)(mV) | 5 |
RoHS | Не совместим |
- Understanding Operational Amplifier SpecificationsPDF, 273 Кб, Файл опубликован: 13 июл 1998
Selecting the right operational amplifier for a specific application requires you to have your design goals clearly in mind along with a firm understanding of what the published specifications mean. This paper addresses the issue of understanding data sheet specifications.This paper begins with background information. First introductory topics on the basic principles of amplifiers are presen - Handbook of Operational Amplifier Applications (Rev. B)PDF, 2.8 Мб, Версия: B, Файл опубликован: 19 сен 2016
While in the process of reviewing Texas Instruments applications notes including those from Burr-Brown - I uncovered a couple of treasures this handbook on op amp applications and one on active RC networks. These old publications from 1963 and 1966 respectively are some of the finest works on op amp theory that I have ever seen. Nevertheless they contain some material that is hopelessly outd
Серия: UA741 (15)
- Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > General-Purpose Op Amps
