Datasheet Texas Instruments PCA9543ADR — Даташит
Серия | PCA9543A |
Модель | PCA9543ADR |
![Datasheet Texas Instruments PCA9543ADR](http://www.ti.com/graphics/folders/partimages/PCA9543A.jpg)
Двухканальный переключатель шины I2C с логикой прерываний и сбросом 14-SOIC от -40 до 85
PCA9543A 2-Channel I2C Bus Switch With Interrupt Logic and Reset datasheet
PDF, 1.0 Мб, Версия: A, Файл опубликован: 12 июн 2014
![]() 20 предложений от 13 поставщиков I2C Multiplexer 1Element Open Drain 2IN 14Pin SOIC T/R | |||
PCA9543ADR Texas Instruments | 45 ₽ | ||
PCA9543ADR Texas Instruments | от 56 ₽ | ||
PCA9543ADR Texas Instruments | по запросу | ||
Pin | 14 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | PCA9543A |
Width (мм) | 3.91 |
Length (мм) | 8.65 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Channel Width | 2 |
I2C Address | 1110 0xx |
Package Group | SOIC |
Simultaneously Active Channels | 1 to 2 |
Special Features | Interrupt Output,Reset Input,5V Tolerant I/O |
VCC(Max) | 5.5 В |
VCC(Min) | 2.3 В |
fSCLK(Max) | 0.4 МГц |
tpd max | 1 нс |
- Programming Fun Lights With TI's TCA6507PDF, 109 Кб, Файл опубликован: 30 ноя 2007
- Choosing the Correct I2C Device for New DesignsPDF, 87 Кб, Файл опубликован: 7 сен 2016
The I2C bus is a very popular and powerful bus used for communication between a single (or multiple)master and a single (or multiple) slave device. In many applications there is a potential need for moreslave devices on the bus, isolation between similar addressed slaves, or a need for more I/Os. Theseneeds can be solved with an I2C buffer, switch, and I/O expander.The application note h - Maximum Clock Frequency of I2C Bus Using RepeatersPDF, 116 Кб, Файл опубликован: 15 май 2015
TCA9617 Maximum Allowed Frequency on I2C Bus Using Repeaters - I2C Bus Pull-Up Resistor CalculationPDF, 157 Кб, Файл опубликован: 13 фев 2015
- Understanding the I2C BusPDF, 124 Кб, Файл опубликован: 30 июн 2015
Серия: PCA9543A (6)
- PCA9543AD PCA9543ADG4 PCA9543ADR PCA9543APW PCA9543APWR PCA9543APWRG4
- Semiconductors > Interface > I2C > I2C Switches and Multiplexers
