Datasheet Texas Instruments SN74LVC126AQDRG4Q1 — Даташит
Серия | SN74LVC126A-Q1 |
Модель | SN74LVC126AQDRG4Q1 |
Автомобильный каталог Четверной буферный вентиль шины с выходами с 3 состояниями, 14-SOIC -40–125
Quadruple Bus Buffer Gate With 3-State Outputs datasheet
PDF, 792 Кб, Версия: B, Файл опубликован: 9 апр 2008
Купить SN74LVC126AQDRG4Q1 на РадиоЛоцман.Цены — от 16 до 37 ₽ 12 предложений от 9 поставщиков Buffer, Non-Inverting 4 Element 1 Bit per Element 3-State Output 14-SOIC | |||
SN74LVC126AQDRG4Q1 Texas Instruments | 16 ₽ | ||
SN74LVC126AQDRG4Q1 Texas Instruments | 17 ₽ | ||
SN74LVC126AQDRG4Q1 Texas Instruments | по запросу |
Pin | 14 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | LC126AQ |
Width (мм) | 3.91 |
Length (мм) | 8.65 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Bits | 4 |
F @ Nom Voltage(Max) | 100 Mhz |
ICC @ Nom Voltage(Max) | 0.02 мА |
Output Drive (IOL/IOH)(Max) | -24/24 мА |
Package Group | SOIC |
Package Size: mm2:W x L | 14SOIC: 52 mm2: 6 x 8.65(SOIC) PKG |
Rating | Automotive |
Schmitt Trigger | No |
Technology Family | LVC |
VCC(Max) | 3.6 В |
VCC(Min) | 1.65 В |
Voltage(Nom) | 1.8,2.5,2.7,3.3 В |
tpd @ Nom Voltage(Max) | 6.2,5.7 нс |
- LVC Characterization InformationPDF, 114 Кб, Файл опубликован: 1 дек 1996
This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices. - Use of the CMOS Unbuffered Inverter in Oscillator CircuitsPDF, 796 Кб, Файл опубликован: 6 ноя 2003
CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC126A-Q1 (3)
- CLVC126AQPWRG4Q1 SN74LVC126AQDRG4Q1 SN74LVC126AQDRQ1
- Semiconductors > Logic > Buffer/Driver/Transceiver > Non-Inverting Buffer/Driver
