Datasheet Texas Instruments SN74LVC138APWRE4 — Даташит
Серия | SN74LVC138A |
Модель | SN74LVC138APWRE4 |
Декодер/демультиплексор от 3 до 8 строк 16-TSSOP от -40 до 85
SN74LVC138A 3-Line to 8-Line Decoders Demultiplexers datasheet
PDF, 1.5 Мб, Версия: W, Файл опубликован: 11 ноя 2016
Купить SN74LVC138APWRE4 на РадиоЛоцман.Цены — от 6.73 до 39 ₽ 12 предложений от 9 поставщиков Decoder/Demultiplexer 1 x 3:8 16-TSSOP | |||
SN74LVC138APWRE4 Texas Instruments | 6.73 ₽ | ||
SN74LVC138APWRE4 Texas Instruments | 11 ₽ | ||
SN74LVC138APWRE4 Texas Instruments | по запросу | ||
Pin | 16 |
Package Type | PW |
Industry STD Term | TSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | LC138A |
Width (мм) | 4.4 |
Length (мм) | 5 |
Thickness (мм) | 1 |
Pitch (мм) | .65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Полоса частот | 100 МГц |
Bits | 8 |
Количество каналов | 1 |
Configuration | 3:8 |
Digital input leakage(Max) | 5 uA |
ESD Charged Device Model | 0.75 kV |
ESD HBM | 2 kV |
F @ Nom Voltage(Max) | 100 Mhz |
Function | Decoder/Demultiplexer |
ICC @ Nom Voltage(Max) | 0.01 мА |
Output Drive (IOL/IOH)(Max) | 24/-24 мА |
Package Group | TSSOP |
Package Size: mm2:W x L | 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | LVC |
Тип | Standard |
VCC(Max) | 3.6 В |
VCC(Min) | 1.65 В |
Voltage(Nom) | 1.8,2.5,2.7,3.3 В |
tpd @ Nom Voltage(Max) | 22,9.9,7.9,6.7 нс |
- LVC Characterization InformationPDF, 114 Кб, Файл опубликован: 1 дек 1996
This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices. - Use of the CMOS Unbuffered Inverter in Oscillator CircuitsPDF, 796 Кб, Файл опубликован: 6 ноя 2003
CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC138A (27)
- SN74LVC138AD SN74LVC138ADBLE SN74LVC138ADBR SN74LVC138ADBRE4 SN74LVC138ADBRG4 SN74LVC138ADE4 SN74LVC138ADG4 SN74LVC138ADGVR SN74LVC138ADR SN74LVC138ADRE4 SN74LVC138ADRG4 SN74LVC138ADT SN74LVC138AGQNR SN74LVC138ANSR SN74LVC138ANSRG4 SN74LVC138APW SN74LVC138APWE4 SN74LVC138APWG4 SN74LVC138APWLE SN74LVC138APWR SN74LVC138APWRE4 SN74LVC138APWRG4 SN74LVC138APWT SN74LVC138ARGYR SN74LVC138ARGYRG4 SN74LVC138ARSVR SN74LVC138AZQNR
- Semiconductors > Switches and Multiplexers > Buffered Encoders and Decoders
