Datasheet Texas Instruments TPS7101QPWR — Даташит
Серия | TPS71 |
Модель | TPS7101QPWR |
![Datasheet Texas Instruments TPS7101QPWR](http://www.ti.com/graphics/folders/partimages/TPS71.jpg)
Стабилизатор напряжения с низким падением напряжения, 500 мА, 20-TSSOP от -40 до 125
Low-Dropout Voltage Regulators datasheet
PDF, 1.3 Мб, Версия: G, Файл опубликован: 22 янв 2003
![]() 15 предложений от 10 поставщиков Dual Channel LDO Lowest Dropout (LDO) PMOS Adjustable Voltage Regulator LDO Regulator Pos 1.2V to 9.75V 0.5A 20Pin TSSOP T/R | |||
TPS7101QPWR Texas Instruments | от 47 ₽ | ||
TPS7101QPWR Texas Instruments | 109 ₽ | ||
TPS7101QPWR Texas Instruments | 169 ₽ | ||
TPS7101QPWR Texas Instruments | по запросу |
Pin | 20 |
Package Type | PW |
Industry STD Term | TSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Width (мм) | 4.4 |
Length (мм) | 6.5 |
Thickness (мм) | 1 |
Pitch (мм) | 0.65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Точность | 3 % |
Основные особенности | Enable,Power Good |
Fixed Output Options | 3.3,4.8,5 В |
Iout(Max) | 0.5 A |
Iq(Typ) | 0.28 мА |
Noise | 89 uVrms |
Output Capacitor Type | Non-Ceramic |
Output Options | Adjustable Output,Fixed Output |
PSRR @ 100KHz | 3 дБ |
Package Group | TSSOP |
Package Size: mm2:W x L | 20TSSOP: 42 mm2: 6.4 x 6.5(TSSOP) PKG |
Rating | Catalog |
Regulated Outputs | 1 |
Thermal Resistance ОёJA | 106 В°C/W |
Vdo(Typ) | 235 мВ |
Vin(Max) | 10 В |
Vin(Min) | 2.5 В |
Vout(Max) | 9.75 В |
Vout(Min) | 1.2 В |
- TMS320C62x/67x Power Supply Solutions for 1-2 DSPs Using the TL5001A and TPS7133 (Rev. A)PDF, 190 Кб, Версия: A, Файл опубликован: 1 июн 1999
This application report describes a low-cost power solution for Texas Instruments' TMS320C6000 DSP applications using the TL5001PWM controller and the TPS7133 low drop-out voltage regulator. The reference design included in this report uses the TL5001AEVM-122 (SLVP122) evaluation module (EVM) which is available for customer testing and evaluation. - Power Supply Sequencing Solutions for Dual Supply Voltage DSPs (Rev. A)PDF, 104 Кб, Версия: A, Файл опубликован: 5 июл 2000
This application report describes power-supply sequencing recommendations and techniques applicable to dual supply voltage DSPs in TI's TMS320C2000 TMS320C5000 and TMS320C6000 families. These techniques take advantage of the reset power good enable and soft-start features available on TI Power Management Products including low drop out regulators switching power supply controllers supply vol - Technical Review of Low Dropout Voltage Regulator Operation And PerformancePDF, 284 Кб, Файл опубликован: 30 авг 1999
This application report provides a technical review of low dropout (LDO) voltage regulators and describes fundamental concepts including dropout voltage quiescent current and topologies. The report also includes detailed discussions of load/line regulation efficiency frequency response range of stable ESR and accuracy of LDO voltage regulators. - Fundamental Theory of PMOS LDO Voltage RegulatorsPDF, 66 Кб, Файл опубликован: 7 май 1999
This report presents a fundamental understanding on the theory of low-dropout voltage regulators using a PMOS FET as the pass element to adjust the output current to the load requirements. - LDO Noise Demystified (Rev. A)PDF, 785 Кб, Версия: A, Файл опубликован: 9 авг 2017
Thisapplicationreportexplainsthe differencebetweennoiseand PSRRof an LDO.It also explainsthedifferentwaysnoiseis specifiedin LDOdatasheetsandwhichspecificationshouldbe usedin theapplication.Finallyit explainshow LDOnoiseis reduced. - LDO PSRR Measurement Simplified (Rev. A)PDF, 131 Кб, Версия: A, Файл опубликован: 9 авг 2017
Серия: TPS71 (28)
- TPS7101QD TPS7101QDG4 TPS7101QDR TPS7101QDRG4 TPS7101QP TPS7101QPW TPS7101QPWLE TPS7101QPWR TPS7133QD TPS7133QDG4 TPS7133QDR TPS7133QDRG4 TPS7133QP TPS7133QPE4 TPS7133QPWLE TPS7133QPWPLE TPS7133QPWR TPS7148QD TPS7148QDG4 TPS7148QP TPS7148QPE4 TPS7148QPWLE TPS7150QD TPS7150QDG4 TPS7150QDR TPS7150QDRG4 TPS7150QP TPS7150QPWLE
