Datasheet Texas Instruments ADS7846IRGVTG4 — Даташит
Серия | ADS7846 |
Модель | ADS7846IRGVTG4 |
4-проводной контроллер сенсорного экрана 16-VQFN от -40 до 85
Touch-Screen Controller datasheet
PDF, 1.5 Мб, Версия: H, Файл опубликован: 27 янв 2005
Купить ADS7846IRGVTG4 на РадиоЛоцман.Цены — от 128 до 331 ₽ 16 предложений от 10 поставщиков Touch Screen Controller 16Pin VQFN EP T/R | |||
ADS7846IRGVTG4 Texas Instruments | от 128 ₽ | ||
ADS7846IRGVTG4 Texas Instruments | от 130 ₽ | ||
ADS7846IRGVTG4 Texas Instruments | 308 ₽ | ||
ADS7846IRGVTG4 Texas Instruments | 329 ₽ |
Pin | 16 | 16 |
Package Type | RGV | RGV |
Industry STD Term | VQFN | VQFN |
JEDEC Code | S-PQFP-N | S-PQFP-N |
Package QTY | 250 | 250 |
Carrier | SMALL T&R | SMALL T&R |
Маркировка | ADS | 7846 |
Width (мм) | 4 | 4 |
Length (мм) | 4 | 4 |
Thickness (мм) | .9 | .9 |
Pitch (мм) | .65 | .65 |
Max Height (мм) | 1 | 1 |
- Set Up and Use TSC TimingsPDF, 271 Кб, Файл опубликован: 7 июн 2007
This application report helps users to understand, set up, and use the programming timings in the register-based touch screen controller (TSC) devices. It displays the timings functions and discusses the effect on the system interface traffic and on the system power consumption. - Evaluating the ADS7846E: Using the DEM-ADS7843E/45E Evaluation FixturePDF, 44 Кб, Файл опубликован: 27 сен 2000
The ADS7846 is the next-generation version to the industry standard ADS7843 4-wire touch-screen controller. The ADS7846 is 100% pin-compatible with the existing ADS7843, and will drop into the same socket. This allows for easy upgrade of current applications to the new version. - Using the ADS7846 Touch Screen Ctrl. with the Intel SA-1110 StrongArm ProcessorPDF, 81 Кб, Файл опубликован: 19 сен 2001
The Intel SA-1110 StrongArm processor is a popular platform for development of personal digital assistants (PDAs) and other hand-held computing devices. The human interface for these devices is generally a touch screen. This application report provides information on connecting the TI ADS7846 touch screen controller to an SA-1110, and provides documentation for a Windows CE driver that has been de - Using a touch-screen controller’s auxiliary inputsPDF, 149 Кб, Файл опубликован: 12 окт 2007
- Touch Screen Controller TipsPDF, 86 Кб, Файл опубликован: 27 сен 2000
The ADS7843, ADS7845, and the new ADS7846 converters all are designed for specific touch screen applications. Applications using these devices can benefit greatly from the tips presented in this application bulletin. Most of the examples discuss the ADS7843, but the techniques shown are applicable to all of the devices. - PCB Layout Guideline for TI Resistive TSC DevicesPDF, 144 Кб, Файл опубликован: 4 окт 2012
- Operation Schemes of Touch Screen ControllersPDF, 846 Кб, Файл опубликован: 21 май 2007
- Reducing Analog Input Noise in Touch Screen Systems (Rev. A)PDF, 535 Кб, Версия: A, Файл опубликован: 15 сен 2007
This application report discusses some common methods for reducing noise in the analog input circuitry of a resistive touch screen controller. In terms of hardware design, PCB layout and grounding are critical; the additional noise-decoupling capacitor built into a touch screen controller input pin may also help. On the software side, several simple, widely-applied filtering algorithms are present - Calibration in touch-screen systemsPDF, 169 Кб, Файл опубликован: 10 авг 2007
- Q4 2007 Issue Analog Applications Journal (Rev. A)PDF, 316 Кб, Версия: A, Файл опубликован: 14 ноя 2007
- Apply TI TSC for Various and Multiple FunctionsPDF, 316 Кб, Файл опубликован: 11 дек 2006
This application report presents several examples showing how a touch screen controller (TSC) from Texas Instruments provides a variety of functions such as graphs, scroll bars, pressure buttons, and analog dials. A simple resistive TSC can be used to achieve all of these functions as long as they are not activated simultaneously. This application report demonstrates a few simple examples how th - Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference. - Principles of Data Acquisition and Conversion (Rev. A)PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
Серия: ADS7846 (10)
- Semiconductors > Data Converters > Integrated/Special Function Data Converters > Touch Screen Controllers
