Datasheet Texas Instruments BQ24195 — Даташит
Серия | BQ24195 |
I2C Controlled 2.5A/4.5A Single Cell Charger with 5.1V 1.3A/2.1A Synchronous Boost Operation
bq24195 I2C Controlled 2.5-A /4.5-A Single Cell USB/Adapter Charger with 5.1 V at 1 A /5.1 V at 2.1 A Synchronous Boost Operation datasheet
PDF, 2.4 Мб, Версия: A, Файл опубликован: 30 дек 2014
Купить BQ24195 на РадиоЛоцман.Цены — от 84 до 687 ₽ 32 предложений от 21 поставщиков I2C Controlled 2.5A/4.5A Single Cell Charger with 5.1V 1.3A/2.1A Synchronous Boost Operation 24-VQFN -40℃ to 85℃ | |||
BQ24195LRGER Texas Instruments | от 84 ₽ | ||
BQ24195LRGER Texas Instruments | 96 ₽ | ||
BQ24195LRGET Texas Instruments | 197 ₽ | ||
BQ24195LRGET Texas Instruments | по запросу |
BQ24195RGER | BQ24195RGET | |
Статус продукта | В производстве | В производстве |
Доступность образцов у производителя | Да | Нет |
N | 1 | 2 |
Pin | 24 | 24 |
Package Type | RGE | RGE |
Industry STD Term | VQFN | VQFN |
JEDEC Code | S-PQFP-N | S-PQFP-N |
Package QTY | 3000 | 250 |
Carrier | LARGE T&R | SMALL T&R |
Маркировка | BQ24195 | BQ24195 |
Width (мм) | 4 | 4 |
Length (мм) | 4 | 4 |
Thickness (мм) | .88 | .88 |
Pitch (мм) | .5 | .5 |
Max Height (мм) | 1 | 1 |
Parameters / Models | BQ24195RGER | BQ24195RGET |
Absolute Vin (safety rating)(Max)(, В | 22 | 22 |
Battery Charge Voltage(Max), В | 4.4 | 4.4 |
Battery Charge Voltage(Min), В | 3.5 | 3.5 |
Cell Chemistry | Li-Ion/Li-Polymer | Li-Ion/Li-Polymer |
Charge Current(Max), A | 4.5 | 4.5 |
Control Interface | I2C,Standalone (RC-Settable) | I2C,Standalone (RC-Settable) |
Control Topology | Switch-Mode Buck | Switch-Mode Buck |
Number of Series Cells | 1 | 1 |
Operating Vin(Max), В | 17 | 17 |
Operating Vin(Min), В | 3.9 | 3.9 |
Package Group | VQFN | VQFN |
Package Size: mm2:W x L, PKG | 24VQFN: 16 mm2: 4 x 4(VQFN) | 24VQFN: 16 mm2: 4 x 4(VQFN) |
Special Features | Integrated FET,OTG (On The Go Boost),Power Path,Temp Monitoring (Thermistor Pin),Thermal Regulation,Vin DPM (OK for Solar Power Source) | Integrated FET,OTG (On The Go Boost),Power Path,Temp Monitoring (Thermistor Pin),Thermal Regulation,Vin DPM (OK for Solar Power Source) |
USB Feature | USB Detection,USB OTG | USB Detection,USB OTG |
Серия: BQ24195 (2)
- Semiconductors> Power Management> Battery Management Products> Battery Charger IC
