Datasheet Texas Instruments BQ27410-G1 — Даташит
СерияBQ27410-G1
System-Side Impedance Trackв„ў Fuel (Gas) Gauge With Direct Battery Connection
System Side Impedance Track Fuel Gauge - bq27410-G1 datasheet
PDF, 1.4 Мб, Файл опубликован: 6 дек 2010
System-Side Impedance Track?„? Fuel Gauge With Direct Battery Connection
TradeElectronics
BQ27410-G1по запросу
BQ27410DRZR-G1BQ27410DRZT-G1
Статус продуктаНе рекомендуется для новых разработокНе рекомендуется для новых разработок
N12
Pin1212
Package TypeDRZDRZ
Industry STD TermVSONVSON
JEDEC CodeS-PDSO-NS-PDSO-N
Package QTY2500250
CarrierLARGE T&RSMALL T&R
МаркировкаBQ7410
Width (мм)2.52.5
Length (мм)44
Thickness (мм).85.85
Pitch (мм).4.4
Max Height (мм)11
RoHSСовместимСовместим
  • Single Cell Gas Gauge Circuit Design
    PDF, 154 Кб, Файл опубликован: 22 фев 2008
  • Theory and Implementation of Impedance Track Battery Fuel-Gauging Algorithm
    PDF, 608 Кб, Файл опубликован: 31 янв 2008
    This application report outlines the theory of Impedance Trackв„ў (IT) technology used in the bq2750x series of fuel gauge ICs for single-cell Li-ion applications (e.g., smart phones, media players, and PDAs). The implementation of the IT algorithm in the bq2750x family is reviewed, and the settings of data flash constants associated with the fuel-gauging algorithm is described in detail.
  • Single Cell Impedance Track Printed-Circuit Board Layout
    PDF, 403 Кб, Файл опубликован: 22 фев 2008
    bq20z70/90 Printed-Circuit Board Layout Guide
  • WinCE/Linux Drivers for bq275xx Fuel Gauge
    PDF, 188 Кб, Файл опубликован: 17 мар 2011
    The bq275xx gas gauge integrated circuits (IC) can use an I2C line for communication with the host system. It is necessary to allow application-layer software on the host system to access parameters made available by the gas gauge IC. Multiple levels of abstraction are between the gauge and a given application. This document describes an example implementation of each of these layers in an effo
  • Going to Production With the bq274xx Family of Gas Gauges
    PDF, 1.2 Мб, Файл опубликован: 27 июн 2011
    This application report presents a strategy for high-speed, economical calibration and production programming of the bq274xx single-cell gas gauge. Flowchart examples are provided, along with step-by-step instructions for preparing a calibration data set that is required when creating the Golden Data Flash Image (DFI) that is programmed into all bq274xx devices on the production line.
  • MSP430 Based Lithium-Ion Polymer Battery Charging and Gauging Solution Using USB (Rev. A)
    PDF, 1.3 Мб, Версия: A, Файл опубликован: 27 июн 2012
    The use of USB power to charge Lithium-Ion Polymer (LiPo) batteries in electronic systems and devices has become quite popular. To assist in the development of such circuitry in embedded system applications, this application report provides the details on the hardware and software requirements needed to not only implement a battery charging solution using the bq24230 battery charger and the MSP
  • How to Configure and Use the bq27410
    PDF, 1.8 Мб, Файл опубликован: 27 июн 2011
    TI’s Impedance Track (IT)™ fuel gauge is designed for accurately reporting battery remaining capacity and run time. It is `necessary to configure and use the gauge correctly to achieve this. The bq27410 differs from the traditional IT-based gauges which require battery chemistry information and a learning cycle to achieve high accuracy. The bq27410 does not require battery chemistry selection o
Серия: BQ27410-G1 (2)
  • Semiconductors> Power Management> Battery Management Products> Battery Fuel Gauge
На английском языке: Datasheet Texas Instruments BQ27410-G1
