Datasheet Texas Instruments BQ27541 — Даташит
Серия | BQ27541 |
Single Cell Li-Ion Battery Fuel Gauge for Battery Pack Integration
Single Cell Li-Ion Battery Fuel Gauge for Battery Pack Integration datasheet
PDF, 1.1 Мб, Файл опубликован: 10 дек 2008
Купить BQ27541 на РадиоЛоцман.Цены — от 85 до 863 ₽ 27 предложений от 20 поставщиков Single Cell Li-Ion Battery Fuel Gauge for Battery Pack Integration 12-SON -40℃ to 85℃ | |||
BQ27541DRZR Texas Instruments | от 85 ₽ | ||
BQ27541DRZR-V200 Texas Instruments | 119 ₽ | ||
BQ27541-V200_1004 Texas Instruments | по запросу | ||
BQ27541DRZT-G1 Texas Instruments | по запросу |
BQ27541DRZR | BQ27541DRZT | |
Статус продукта | Не рекомендуется для новых разработок | Не рекомендуется для новых разработок |
Доступность образцов у производителя | Нет | Нет |
N | 1 | 2 |
Pin | 12 | 12 |
Package Type | DRZ | DRZ |
Industry STD Term | VSON | VSON |
JEDEC Code | S-PDSO-N | S-PDSO-N |
Package QTY | 3000 | 250 |
Carrier | LARGE T&R | SMALL T&R |
Маркировка | BQ | 7541 |
Width (мм) | 2.5 | 2.5 |
Length (мм) | 4 | 4 |
Thickness (мм) | .85 | .85 |
Pitch (мм) | .4 | .4 |
Max Height (мм) | 1 | 1 |
- ESD and RF Mitigation in Handheld Battery Pack ElectronicsPDF, 68 Кб, Файл опубликован: 6 мар 2008
It is imperative to protect the electronics in a consumer-removable battery pack from ESD damage. Even an upset without permanent damage may be unacceptable to the end-user. Handheld equipment that contains a transmitter also may require protection to guard against improper measurement and/or upset due to the affect of the radio frequency (RF) on the circuitry. Because the RF field strength varies - Going to Production With the bq2754x (Rev. A)PDF, 581 Кб, Версия: A, Файл опубликован: 11 мар 2011
This application report presents a strategy for high speed, economical calibration, and production programming of the bq2754x single-cell gas gauge. Flowchart examples are provided, along with step-by-step instructions for preparing a calibration data set that is required when creating the golden data flash image (DFI) that is programmed into all bq2754x at the pack maker production line. - bq27541 to bq27541-v200 Change ListPDF, 40 Кб, Файл опубликован: 17 фев 2010
This document describes the design changes from the bq27541 (firmware version 1.12) to bq27541-v200 (firmware version 2.00). For ordering information and data sheet, see the Texas Instruments Web site. - bq27541-v200 to bq27541-G1 Change List (Rev. A)PDF, 43 Кб, Версия: A, Файл опубликован: 21 окт 2012
bq27541-v200, bq27541-G1 bq27541-v200 to bq27541-G1 CHANGE LIST PMP/BMS/Handheld/2-App_Reports/SLUA641_Change_List/bq27541-v200_ChangeList - Thermistor Selection Guide for Texas Instruments Advanced Fuel GaugesPDF, 564 Кб, Файл опубликован: 28 сен 2011
bq20z40, bq20z45, bq20z60, bq20z65, bq20z70, bq20z75, bq20z80, bq20z90, bq20z95, bq27410, Thermistor Selection Guide for Texas Instruments Advanced Fuel Guages - WinCE/Linux Drivers for bq275xx Fuel GaugePDF, 188 Кб, Файл опубликован: 17 мар 2011
The bq275xx gas gauge integrated circuits (IC) can use an I2C line for communication with the host system. It is necessary to allow application-layer software on the host system to access parameters made available by the gas gauge IC. Multiple levels of abstraction are between the gauge and a given application. This document describes an example implementation of each of these layers in an effo - How to Transfer bq27541 Into Hibernate ModePDF, 42 Кб, Файл опубликован: 13 апр 2010
This document presents a checklist and a discussion on how to transfer reliably the bq27541 into Hibernate mode. - Configuring the bq2754x Data FlashPDF, 1.2 Мб, Файл опубликован: 27 май 2009
The bq2754x has many data flash constants that can configure the device with various, different options for most features. The data flash of the bq2754x is divided into sections, which are described in detail in this document. - Fine tuning TI's Impedance Trackв„ў battery fuel gauge with LiFePO4 cellsPDF, 153 Кб, Файл опубликован: 14 мар 2011
- Selecting an Impedance Track Gas Gauge for Li-Ion Single Cell ApplicationsPDF, 78 Кб, Файл опубликован: 10 апр 2012
- Updating bq275xx Firmware at Production (Rev. A)PDF, 107 Кб, Версия: A, Файл опубликован: 21 фев 2011
bq27500 bq27500-V100 bq27500-V120 bq27500-V130 bq27501 bq27505 bq27505-J2 bq27505-J3 bq275 Updating bq275xx Firmware at Production - Improving Battery Safety, Charging, and Fuel Gauging in Portable Media AppsPDF, 570 Кб, Файл опубликован: 11 мар 2009
- Gauge CommunicationPDF, 79 Кб, Файл опубликован: 12 янв 2017
- How to Generate Golden Image for Single-Cell Impedance Track(TM) DevicesPDF, 964 Кб, Файл опубликован: 7 янв 2010
Texas Instruments advanced fuel gauges, employing the Impedance Trackв„ў algorithm, offer an unmatched array of features and benefits. Sometimes, however, the learning cycle to generate the golden image may seem a little challenging. In addition, determining the correct chemistry model and producing the golden image file can be time consuming. This application report describes the necessary p - Updating Firmware with the bq2750x and EVM (Rev. A)PDF, 955 Кб, Версия: A, Файл опубликован: 22 июл 2008
This application report provides the procedure to update bq2750x firmware and the learned golden image (*.DFI file) in bq27500 data flash from the previous firmware version. - Impedance Track Fuel Gauge Accuracy Test for GSM Phone ApplicationsPDF, 393 Кб, Файл опубликован: 21 мар 2008
The Texas Instruments Impedance Trackв„ў (IT) fuel gauge is designed for reporting remaining battery capacity and run time accurately. To effectively accomplish this reporting a real application environment must be used for test results. The test board should be designed as similar to the real application circuit as possible. This application report outlines the procedure for implementing an accurac - Using I2C Communication With the bq275xx Series of Fuel Gauges (Rev. B)PDF, 53 Кб, Версия: B, Файл опубликован: 15 май 2014
- Achieving the Successful Learning CyclePDF, 46 Кб, Файл опубликован: 12 май 2011
bq27500, bq27501, bq27510, bq27505, bq27541, bq27520 Achieving the Successful Learning Cycle - Configuring the bq27541-V200 Data Flash (Rev. B)PDF, 1.5 Мб, Версия: B, Файл опубликован: 9 мар 2011
- Theory and Implementation of Impedance Track Battery Fuel-Gauging AlgorithmPDF, 608 Кб, Файл опубликован: 31 янв 2008
This application report outlines the theory of Impedance Trackв„ў (IT) technology used in the bq2750x series of fuel gauge ICs for single-cell Li-ion applications (e.g., smart phones, media players, and PDAs). The implementation of the IT algorithm in the bq2750x family is reviewed, and the settings of data flash constants associated with the fuel-gauging algorithm is described in detail. - Single Cell Gas Gauge Circuit DesignPDF, 154 Кб, Файл опубликован: 22 фев 2008
- Single Cell Impedance Track Printed-Circuit Board LayoutPDF, 403 Кб, Файл опубликован: 22 фев 2008
bq20z70/90 Printed-Circuit Board Layout Guide - Configuring the bq2754x-G1 Data FlashPDF, 1.1 Мб, Файл опубликован: 16 окт 2012
bq27541-G1, bq27545-G1, bq27541EVM, bq27545EVM Configuring the bq2754x-G1 Data Flash - Host-Side Gas-Gauge-System Design Considerations for Single-Cell Handheld AppsPDF, 152 Кб, Файл опубликован: 12 окт 2007
- Single Cell Gas Gauge Application BookPDF, 9.7 Мб, Файл опубликован: 28 июл 2008
- Host System Calibration Method (Rev. B)PDF, 140 Кб, Версия: B, Файл опубликован: 19 май 2016
To add improvements to the Impedance Trackв„ў algorithm, changes have been made to free up firmwarecode space. In the process of freeing up code space, the calibration calculations are no longerautomatically performed by the gauge but must be performed by the host and the results written back tothe gauge. This application note provides a flow on how to implement the calibration algorithm on a - MSP430 Microcontroller SW for Handheld Fuel Gauges and Battery Authentication (Rev. A)PDF, 350 Кб, Версия: A, Файл опубликован: 26 май 2010
MSP430, bq26100, bq26100EVM, bq26150, bq26150EVM, bq26500, bq27000, bq27000EVM, bq27200, b MSP430 Microcontroller Software for Handheld Fuel Gauge & Battery Authentication
Серия: BQ27541 (2)
- Semiconductors> Power Management> Battery Management Products> Battery Fuel Gauge
