Datasheet Texas Instruments BQ76PL536A — Даташит
СерияBQ76PL536A
Lithium-Ion Battery Monitor and Secondary Protection IC for Electric and Hybrid
bq76PL536A 3-to-6 Series Cell Lithium-Ion Battery Monitor and Secondary Protection IC for Applications datasheet
PDF, 2.0 Мб, Версия: C, Файл опубликован: 19 окт 2016
Acme Chip
BQ76PL536A
BQ76PL536APAPRBQ76PL536APAPT
Доступность образцов у производителяДаНет
N12
Pin6464
Package TypePAPPAP
Industry STD TermHTQFPHTQFP
JEDEC CodeS-PQFP-GS-PQFP-G
Package QTY1000250
CarrierLARGE T&RSMALL T&R
МаркировкаBQ76PL536ABQ76PL536A
Width (мм)1010
Length (мм)1010
Thickness (мм)11
Pitch (мм).5.5
Max Height (мм)1.21.2
Parameters / ModelsBQ76PL536APAPR
BQ76PL536APAPR
BQ76PL536APAPT
BQ76PL536APAPT
Communication InterfaceSPISPI
FunctionMonitoring (Analog Front-End)Monitoring (Analog Front-End)
Number of Series Cells, Max33
Package GroupHTQFPHTQFP
Protection Feature, sOver-temperature (OT),Over-voltage (OV),Under-voltage (UV)Over-temperature (OT),Over-voltage (OV),Under-voltage (UV)
RatingCatalogCatalog
Special FeaturesCell Balancing,Integrated ADC,Programmable EEPROM or EPROM,Requires separate MCU,Stackable (built-in interface)Cell Balancing,Integrated ADC,Programmable EEPROM or EPROM,Requires separate MCU,Stackable (built-in interface)
Typical Operating Current(Typ), uA4545
Vin(Max), В2727
RoHSСовместимСовместим
  • Improving Communications With the bq76PL536
    PDF, 158 Кб, Файл опубликован: 11 авг 2010
    The bq76PL536 is designed to communicate at high speed in noisy conditions present in automotive and industrial large-format battery applications. This document presents specific steps to maximize the integrity of communications with the bq76PL536 and reduce susceptibility to noise to a minimum, thereby reducing the bit-error rate to an acceptable level.
  • bq76PL536/536A/536AQ1 Communication Basics (Rev. B)
    PDF, 71 Кб, Версия: B, Файл опубликован: 5 июл 2011
    This application report discusses the communication basics of addressing, reading, and writing for the Texas Instruments bq76PL536, a stackable 3-to-6 series battery pack protector and analog front end.
  • Multi-Cell Li-Ion Battery Management System Using MSP430F5529 and bq76PL536
    PDF, 118 Кб, Файл опубликован: 16 дек 2010
    This application report explains the implementation of a multi-cell lithium-ion battery management system using an MSP430(tm) microcontroller and the bq76PL536. The battery manager is implemented using the standard evaluation boards for the MSP430 MCU and the bq76PL536.The bq76PL536 can be stacked vertically to monitor up to 192 cells without additional isolation components between ICs. A high-s
Серия: BQ76PL536A (2)
  • Semiconductors> Power Management> Battery Management Products> Battery Monitor, Protection & Authentication Solutions
На английском языке: Datasheet Texas Instruments BQ76PL536A
