Datasheet Texas Instruments CD54HC259 — Даташит
Серия | CD54HC259 |
High Speed CMOS Logic 8-Bit Addressable Latch
CD54HC259, CD74HC259, CD54HCT259, CD74HCT259 datasheet
PDF, 461 Кб, Версия: C, Файл опубликован: 16 окт 2003
6 предложений от 6 поставщиков High-Speed CMOS Logic 8-Bit Addressable Latch | |||
CD54HC259F Texas Instruments | по запросу | ||
CD54HC259F Harris | по запросу | ||
CD54HC259_07 Texas Instruments | по запросу | ||
CD54HC259_06 Texas Instruments | по запросу |
CD54HC259F3A | |
Статус продукта | В производстве |
CD54HC259F3A | |
N | 1 |
Pin | 16 |
Package Type | J |
Industry STD Term | CDIP |
JEDEC Code | R-GDIP-T |
Package QTY | 1 |
Carrier | TUBE |
Маркировка | CD54HC259F3A |
Width (мм) | 6.92 |
Length (мм) | 19.56 |
Thickness (мм) | 4.57 |
Pitch (мм) | 2.54 |
Max Height (мм) | 5.08 |
Mechanical Data | Скачать |
Parameters / Models | CD54HC259F3A |
3-State Output | No |
Bits | 8 |
F @ Nom Voltage(Max), Mhz | 28 |
ICC @ Nom Voltage(Max), мА | 0.08 |
Тип входа | CMOS |
Рабочий диапазон температур, C | от -55 до 125 |
Output Drive (IOL/IOH)(Max), мА | 5.2/-5.2 |
Тип выхода | CMOS |
Package Group | CDIP |
Package Size: mm2:W x L, PKG | See datasheet (CDIP) |
Rating | Military |
Technology Family | HC |
VCC(Max), В | 6 |
VCC(Min), В | 2 |
tpd @ Nom Voltage(Max), нс | 28 |
CD54HC259F3A | |
RoHS | See ti.com |
- Selecting the Right Texas Instruments Signal SwitchPDF, 769 Кб, Файл опубликован: 7 сен 2001
Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi - Power-Up Behavior of Clocked Devices (Rev. A)PDF, 34 Кб, Версия: A, Файл опубликован: 6 фев 2015
- Using High Speed CMOS and Advanced CMOS in Systems With Multiple VccPDF, 43 Кб, Файл опубликован: 1 апр 1996
Though low power consumption is a feature of CMOS devices sometimes this feature does not meet a designer?s system power supply constraints. Therefore a partial system power down or multiple Vcc supplies are used to meet the needs of the system. This document shows electrostatic discharge protection circuits. It also provides circuit and bus driver examples of partial system power down and curren - SN54/74HCT CMOS Logic Family Applications and RestrictionsPDF, 102 Кб, Файл опубликован: 1 май 1996
Серия: CD54HC259 (1)
- Semiconductors> Space & High Reliability> Logic Products> Flip-Flop/Latch/Registers
