Datasheet Texas Instruments DRV8884 — Даташит
Серия | DRV8884 |
1.0A Stepper Motor Driver With 1/16 Microstepping and Integrated Current Sensing (STEP/DIR Ctrl)
DRV8884 1.0-A Stepper Motor Driver With Integrated Current Sense datasheet
PDF, 1.6 Мб, Версия: B, Файл опубликован: 21 апр 2016
Купить DRV8884 на РадиоЛоцман.Цены — от 149 до 517 ₽ 19 предложений от 12 поставщиков Motor / Motion / Ignition Controllers & Drivers 1A Stepper Motor Driver With 1/16 Microstepping and Integrated Current Sensing (STEP/DIR Ctrl)... | |||
DRV8884PWPR Texas Instruments | 149 ₽ | ||
DRV8884RHRR Texas Instruments | 163 ₽ | ||
DRV8884RHR Texas Instruments | 297 ₽ | ||
DRV8884PWPR Texas Instruments | по запросу |
DRV8884PWP | DRV8884PWPR | |
Статус продукта | В производстве | В производстве |
Доступность образцов у производителя | Нет | Да |
N | 1 | 2 |
Pin | 24 | 24 |
Package Type | PWP | PWP |
Industry STD Term | HTSSOP | HTSSOP |
Package QTY | 60 | 2000 |
Carrier | TUBE | LARGE T&R |
Маркировка | DRV8884 | DRV8884 |
Width (мм) | 4.4 | 4.4 |
Length (мм) | 7.8 | 7.8 |
Thickness (мм) | 1 | 1 |
Pitch (мм) | .65 | .65 |
Max Height (мм) | 1.2 | 1.2 |
Parameters / Models | DRV8884PWP | DRV8884PWPR |
Additional Features | Integrated Current Sensing | Integrated Current Sensing |
Control I/F | STEP/DIR | STEP/DIR |
Micro-Stepping Levels | 16 | 16 |
Number of Full Bridges | 2 | 2 |
Рабочий диапазон температур, C | от -40 до 125 | от -40 до 125 |
Package Size: mm2:W x L, PKG | 24HTSSOP: 50 mm2: 6.4 x 7.8(HTSSOP) | 24HTSSOP: 50 mm2: 6.4 x 7.8(HTSSOP) |
Peak Output Current, A | 1 | 1 |
RDS(ON) (HS + LS), mOhms | 1400 | 1400 |
RMS Output Current, A | 0.7 | 0.7 |
Rating | Catalog | Catalog |
Vs(Max), В | 37 | 37 |
Vs(Min), В | 8 | 8 |
- Full-Scale Current Adjustment Using a Digital-to-Analog Converter (DAC)PDF, 1.6 Мб, Файл опубликован: 10 мар 2017
The ability to dynamically control current in an inductive load system is very important for stepper motor designs where different levels of torque control are desired. This adjustment feature can also be used to improve system efficiency by reducing the motor current in low-load situations, achieving a longer battery life.This application report is provided as a supplement t
Серия: DRV8884 (2)
- Semiconductors> Motor Drivers> Stepper Drivers> Stepper Drivers with FETs
