Datasheet Texas Instruments INA230 — Даташит
Серия | INA230 |
28-V, Bi-Directional, Zero-Drift, Low-/High-Side, I2C Out Current/Power Monitor w/ Alert
Bidirectional Current/Power Monitor with I²C™ Interface datasheet
PDF, 1.1 Мб, Файл опубликован: 10 фев 2012
Купить INA230 на РадиоЛоцман.Цены — от 59 до 595 ₽ 27 предложений от 16 поставщиков TEXAS INSTRUMENTS INA230AIRGTT Current Sense Amplifier, Bi-Directional Current, 1 Amplifier, 10μA, QFN, 16Pins, -40℃, 125℃ | |||
INA230AIRGTR Texas Instruments | 59 ₽ | ||
INA230AIRGTR Texas Instruments | 96 ₽ | ||
INA230AIDGSR Texas Instruments | 141 ₽ | ||
INA230AIRGTT Texas Instruments | от 595 ₽ |
INA230AIRGTR | INA230AIRGTT | |
Статус продукта | В производстве | В производстве |
Доступность образцов у производителя | Нет | Да |
N | 1 | 2 |
Pin | 16 | 16 |
Package Type | RGT | RGT |
Industry STD Term | VQFN | VQFN |
JEDEC Code | S-PQFP-N | S-PQFP-N |
Package QTY | 3000 | 250 |
Carrier | LARGE T&R | SMALL T&R |
Маркировка | I230 | I230 |
Width (мм) | 3 | 3 |
Length (мм) | 3 | 3 |
Thickness (мм) | .9 | .9 |
Pitch (мм) | .5 | .5 |
Max Height (мм) | 1 | 1 |
Parameters / Models | INA230AIRGTR | INA230AIRGTT |
Полоса частот, kHz | 3.5 | 3.5 |
CMRR(Min), дБ | 100 | 100 |
Common Mode Voltage(Max), В | 28 | 28 |
Digital Interface | I2C | I2C |
Gain, V/V | 1 | 1 |
Gain Error, % | 0.5 | 0.5 |
Gain Error Drift(Max), ppm/В°C | 50 | 50 |
Input Offset (+/-)(Max), uV | 50 | 50 |
Input Offset Drift (+/-)(Max), uV/C | 0.1 | 0.1 |
Input Offset Drift (+/-)(Typ), uV/C | 0.1 | 0.1 |
Iq(Max), мА | 0.42 | 0.42 |
Рабочий диапазон температур, C | от -40 до 125 | от -40 до 125 |
PSRR(Typ), uV/V | 10 | 10 |
Package Group | VQFN | VQFN |
Package Size: mm2:W x L, PKG | 16VQFN: 9 mm2: 3 x 3(VQFN) | 16VQFN: 9 mm2: 3 x 3(VQFN) |
Rating | Catalog | Catalog |
Special Features | Alert Function,Bi-directional,I2C,Low-side Capable | Alert Function,Bi-directional,I2C,Low-side Capable |
Specified Common Mode Voltage, В | 12 | 12 |
Specified Power Supply Voltage, В | 3.3 | 3.3 |
Supply Voltage(Max), В | 5.5 | 5.5 |
Supply Voltage(Min), В | 2.7 | 2.7 |
- Integrating The Current Sensing Signal Path (Rev. A)PDF, 103 Кб, Версия: A, Файл опубликован: 2 дек 2016
- Integrated Current Sensing Analog-to-Digital ConverterPDF, 88 Кб, Файл опубликован: 21 дек 2016
- Integrating a Current Sense Resistor With a Current Sense Amplifier (Rev. A)PDF, 110 Кб, Версия: A, Файл опубликован: 2 дек 2016
- Precision Low-Side Current Measurement (Rev. B)PDF, 91 Кб, Версия: B, Файл опубликован: 6 мар 2019
- Understanding the I2C BusPDF, 124 Кб, Файл опубликован: 30 июн 2015
Серия: INA230 (2)
- Semiconductors> Amplifiers> Current Sense Amplifiers> Current Sense Power / Current Monitors
