Datasheet Texas Instruments LM36272 — Даташит
Серия | LM36272 |
Двухканальная подсветка ЖК-дисплея и мощность смещения
LM36272 Two-Channel LCD Backlight Driver With Integrated Bias Power datasheet
PDF, 3.1 Мб, Версия: C, Файл опубликован: 23 июн 2017
Купить LM36272 на РадиоЛоцман.Цены — от 69 до 130 ₽ 13 предложений от 10 поставщиков LED Driver IC 2 Output DC DC Regulator Step-Up (Boost) Analog, I²C, PWM Dimming 30mA 24-DSBGA (2.59x1.89) | |||
LM36272YFFR Texas Instruments | 69 ₽ | ||
LM36272YFFR Texas Instruments | 73 ₽ | ||
LM36272YFFR Texas Instruments | 74 ₽ | ||
LM36272YFFR Texas Instruments | по запросу |
LM36272YFFR | |
Статус продукта | В производстве |
LM36272YFFR | |
N | 1 |
Pin | 24 |
Package Type | YFF |
Industry STD Term | DSBGA |
JEDEC Code | S-XBGA-N |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | LM36272 |
Thickness (мм) | .3 |
Pitch (мм) | .4 |
Max Height (мм) | .625 |
Mechanical Data | Скачать |
Parameters / Models | LM36272YFFR |
Количество каналов | 2 |
Duty Cycle(Max), % | 92 |
LED | 16 |
LED Current Per Channel, мА | 30 |
Рабочий диапазон температур, C | от -40 до 85 |
Package Group | DSBGA |
Package Size: mm2:W x L, PKG | See datasheet (DSBGA) |
Peak Efficiency, % | 92 |
Rating | Catalog |
Shutdown Current(Typ), uA | 1.2 |
Special Features | Adjustable Switch Frequency,CABC,Direct PWM Dimming,I2C Control,OVP,Thermal Shutdown |
Switching Frequency(Max), kHz | 1050 |
Topology | Boost,Current Sink |
Тип | Inductive |
Vin(Max), В | 5 |
Vin(Min), В | 2.7 |
Vout(Max), В | 30 |
Vout(Min), В | 27 |
LM36272YFFR | |
- Auto-Frequency Mode Setting for Improved Boost Efficiency in White LED BacklightPDF, 252 Кб, Файл опубликован: 14 окт 2016
As the load current of a boost converter is reduced, the ratio of conduction losses to switching lossesbegins to lower. Conduction losses are losses that are a function of current. Switching losses are lossesthat are a function of switching frequency. As this ratio is reduced the boost switching losses begin todominate the total circuit losses. When this happens, the benefit of lowering the - Analog PWM Dimming in White-LED DriversPDF, 539 Кб, Файл опубликован: 21 дек 2016
Pulse-width modulation (PWM) is a common type of dimming used to adjust the current in white-LEDdriver devices. PWM dimming takes a rectangle waveform with variable positive duty cycle (D) and adjuststhe LED current proportionally. For many smaller format white LED drivers (7-inch screen size or smaller),the PWM signal is converted to a DC control voltage and made to drive the LED current in - Schottky Diode Selection in Asynchronous Boost ConvertersPDF, 491 Кб, Файл опубликован: 6 сен 2016
Asynchronous boost converters require a Schottky diode as the rectifying element due to the diode's lowforward voltage and fast turn-on time. Because of these characteristics asynchronous boost converterscan have as good as, or better efficiency, than synchronous boost converters. This is especially true whenthe boost conversion ratios (VOUT/VIN) are high, and the Schottky diode conduction t - Inductor Selection in Boost Converters for LCD Backlight ApplicationsPDF, 764 Кб, Файл опубликован: 24 окт 2016
White LED drivers for LCD back-light applications are often designed for battery-powered devices. This makes circuit size and efficiency crucial. Because of this, selecting the optimal inductor is one of the mostimportant aspects of the design. This application note discusses the important parameters of the inductorand how to select the right inductor for the application.
Серия: LM36272 (1)
- Semiconductors> Power Management> LED Driver> Backlight
