Datasheet Texas Instruments LM3633 — Даташит
Серия | LM3633 |
Комплексное решение по освещению для смартфонов
LM3633 Complete Lighting Power Solution for Smartphone Handsets datasheet
PDF, 1.5 Мб, Файл опубликован: 4 июн 2014
Купить LM3633 на РадиоЛоцман.Цены — от 56 до 283 ₽ 18 предложений от 11 поставщиков Микросхема: IC LED DRV RGLTR PWM 20DSBGA | |||
LM3633YFQR Texas Instruments | 56 ₽ | ||
LM3633YFQR Texas Instruments | от 59 ₽ | ||
LM3633YFQR Texas Instruments | 79 ₽ | ||
LM3633YFQR Texas Instruments | 83 ₽ |
LM3633YFQR | LM3633YFQT | |
Статус продукта | В производстве | Анонсирован |
Доступность образцов у производителя | Нет | Да |
N | 1 | 2 |
Pin | 20 | 20 |
Package Type | YFQ | YFQ |
Industry STD Term | DSBGA | DSBGA |
JEDEC Code | R-XBGA-N | R-XBGA-N |
Package QTY | 3000 | |
Carrier | LARGE T&R | |
Маркировка | 633B | |
Thickness (мм) | .42 | .42 |
Pitch (мм) | .4 | .4 |
Max Height (мм) | .675 | .675 |
Parameters / Models | LM3633YFQR | LM3633YFQT |
Approx. Price (US$) | 0.70 | 1ku | |
Количество каналов | 3 | |
Channels(#) | 3 | |
Duty Cycle(Max), % | 94 | |
Duty Cycle(Max)(%) | 94 | |
LED | 21 | |
LED Current Per Channel, мА | 30 | |
LED Current Per Channel(mA) | 30 | |
LED(#) | 21 | |
Рабочий диапазон температур, C | от -40 до 85 | |
Operating Temperature Range(C) | -40 to 85 | |
Package Group | DSBGA | DSBGA |
Package Size: mm2:W x L, PKG | See datasheet (DSBGA) | |
Package Size: mm2:W x L (PKG) | See datasheet (DSBGA) | |
Peak Efficiency, % | 90 | |
Peak Efficiency(%) | 90 | |
Rating | Catalog | Catalog |
Shutdown Current(Typ), uA | 1 | |
Shutdown Current(Typ)(uA) | 1 | |
Special Features | Adjustable Switch Frequency,Analog Dimming,CABC,Enable/Shutdown,I2C Control,Integrated Switch,OVP,Synchronous Rectification,Thermal Shutdown | Adjustable Switch Frequency Analog Dimming CABC Enable/Shutdown I2C Control Integrated Switch OVP Synchronous Rectification Thermal Shutdown |
Switching Frequency(Max), kHz | 1100 | |
Switching Frequency(Max)(kHz) | 1100 | |
Topology | Boost | Boost |
Тип | Inductive | Inductive |
Vin(Max), В | 5.5 | |
Vin(Max)(V) | 5.5 | |
Vin(Min), В | 2.7 | |
Vin(Min)(V) | 2.7 | |
Vout(Max), В | 41 | |
Vout(Max)(V) | 41 |
RoHS | Совместим | Не совместим |
- Analog PWM Dimming in White-LED DriversPDF, 539 Кб, Файл опубликован: 21 дек 2016
Pulse-width modulation (PWM) is a common type of dimming used to adjust the current in white-LEDdriver devices. PWM dimming takes a rectangle waveform with variable positive duty cycle (D) and adjuststhe LED current proportionally. For many smaller format white LED drivers (7-inch screen size or smaller),the PWM signal is converted to a DC control voltage and made to drive the LED current in - Schottky Diode Selection in Asynchronous Boost ConvertersPDF, 491 Кб, Файл опубликован: 6 сен 2016
Asynchronous boost converters require a Schottky diode as the rectifying element due to the diode's lowforward voltage and fast turn-on time. Because of these characteristics asynchronous boost converterscan have as good as, or better efficiency, than synchronous boost converters. This is especially true whenthe boost conversion ratios (VOUT/VIN) are high, and the Schottky diode conduction t - Inductor Selection in Boost Converters for LCD Backlight ApplicationsPDF, 764 Кб, Файл опубликован: 24 окт 2016
White LED drivers for LCD back-light applications are often designed for battery-powered devices. This makes circuit size and efficiency crucial. Because of this, selecting the optimal inductor is one of the mostimportant aspects of the design. This application note discusses the important parameters of the inductorand how to select the right inductor for the application.
Серия: LM3633 (2)
- Semiconductors> Power Management> LED Driver> Backlight
