Datasheet Texas Instruments LM3697 — Даташит
Серия | LM3697 |
3-струнный драйвер подсветки с 11-битным экспоненциальным регулированием яркости
LM3697 High-Efficiency Three-String White LED Driver datasheet
PDF, 1.5 Мб, Версия: C, Файл опубликован: 23 окт 2015
Купить LM3697 на РадиоЛоцман.Цены — от 29 до 62 ₽ 22 предложений от 15 поставщиков TEXAS INSTRUMENTS LM3697YFQR Led Driver, 1 Output, Boost (Step Up), 2.7V-5.5V in, 1MHz switch, 40V/30mA out, DSBGA-12 | |||
LM3697YFQR Texas Instruments | 29 ₽ | ||
LM3697YFQR Texas Instruments | 32 ₽ | ||
LM3697YFQR Texas Instruments | по запросу | ||
LM3697YFQR | |
Статус продукта | В производстве |
LM3697YFQR | |
N | 1 |
Pin | 12 |
Package Type | YFQ |
Industry STD Term | DSBGA |
JEDEC Code | R-XBGA-N |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | D8 |
Thickness (мм) | .42 |
Pitch (мм) | .4 |
Max Height (мм) | .675 |
Mechanical Data | Скачать |
Parameters / Models | LM3697YFQR |
Количество каналов | 3 |
Duty Cycle(Max), % | 94 |
LED | 30 |
LED Current Per Channel, мА | 30 |
Рабочий диапазон температур, C | от -40 до 125 |
Package Group | DSBGA |
Package Size: mm2:W x L, PKG | See datasheet (DSBGA) |
Peak Efficiency, % | 91 |
Rating | Catalog |
Shutdown Current(Typ), uA | 1 |
Special Features | I2C Control,OVP,PWM Control |
Switching Frequency(Max), kHz | 1100 |
Topology | Boost |
Тип | Inductive |
Vin(Max), В | 5.5 |
Vin(Min), В | 2.7 |
Vout(Max), В | 41.1 |
LM3697YFQR | |
- Analog PWM Dimming in White-LED DriversPDF, 539 Кб, Файл опубликован: 21 дек 2016
Pulse-width modulation (PWM) is a common type of dimming used to adjust the current in white-LEDdriver devices. PWM dimming takes a rectangle waveform with variable positive duty cycle (D) and adjuststhe LED current proportionally. For many smaller format white LED drivers (7-inch screen size or smaller),the PWM signal is converted to a DC control voltage and made to drive the LED current in
Серия: LM3697 (1)
- Semiconductors> Power Management> LED Driver> Backlight
