ЭФО предлагает со своего склада новую серию преобразователей интерфейсов USB UART компании FTDI FT232RNL-REEL
Datasheet Texas Instruments LM4549B — Даташит
СерияLM4549B
AC '97 Rev 2.1 Codec with Sample Rate Conversion and National 3D Sound
LM4549B AC '97 Rev 2.1 Multi-Channel Audio Codec With Sample Rate Conversion and TI 3D Sound datasheet
PDF, 1.3 Мб, Версия: B, Файл опубликован: 1 июл 2015
ТаймЧипс
LM4549B
LM4549BVH/NOPBLM4549BVHX/NOPB
N12
Pin4848
Package TypePTPT
Industry STD TermLQFPLQFP
JEDEC CodeS-PQFP-GS-PQFP-G
Package QTY2501000
CarrierJEDEC TRAY (10+1)LARGE T&R
МаркировкаLM4549LM4549
Width (мм)77
Length (мм)77
Thickness (мм)1.41.4
Pitch (мм).5.5
Max Height (мм)1.61.6
Parameters / ModelsLM4549BVH/NOPB
LM4549BVH/NOPB
LM4549BVHX/NOPB
LM4549BVHX/NOPB
ADC Channels22
ADC SNR(Typ), дБ9090
Analog Inputs77
Analog Outputs33
DAC Channels22
DAC SNR(Typ), дБ8989
Digital Audio InterfaceI2SI2S
Package Size: mm2:W x L, PKG48LQFP: 81 mm2: 9 x 9(LQFP)48LQFP: 81 mm2: 9 x 9(LQFP)
Sampling Rate(Max), kHz4848
RoHSСовместимСовместим
  • Control Port And Reset Operation SoundPlus Audio Converters and CODECs
    PDF, 77 Кб, Файл опубликован: 27 сен 2000
    This application bulletin provides operational details of the serial control port and reset functions for Burr-Brown digital audio data converters and CODECs. Specifically, this information applies to the PCM1716, PCM1717, PCM1719, PCM1720, PCM1723, PCM1727, PCM3000-series CODECs, and the PCM1800 A/D converter.
  • Configuring I2S to Generate BCLK from Codec Devices & WCLK from McBSP Port
    PDF, 105 Кб, Файл опубликован: 8 июл 2009
    This application note describes a method for interfacing the multichannel buffered serial port (McBSP) to the IВІSв„ў interface of the TLV320AIC32/33/31, theTLV320AIC3101/3104/3105/3106/3204/3254 and TLV320DAC32 devices such that the bit clock (BCLK) is generated by the audio data converter device and the word clock (WCLK) is generated by the McBSP.This type of interface is useful in applications
  • Low Sampling Rate Operation SoundPlus Audio Data Converters and CODECs
    PDF, 291 Кб, Файл опубликован: 27 сен 2000
    This application bulletin describes the operation and performance of Burr-Brown's PCM digital audio products when using low sampling frequencies.
  • Using the MSP430 Launchpad as a Standalone I2C Host for Audio Products (Rev. A)
    PDF, 5.4 Мб, Версия: A, Файл опубликован: 28 окт 2013
  • Solving Enumeration Errors in USB Audio DAC and CODEC Designs
    PDF, 157 Кб, Файл опубликован: 30 окт 2009
    TI’s portfolio of audio digital-to-analog converters (DACs) and coder/decoders (codecs) with integrated USB interfaces offers an excellent building block for any streaming USB audio system. When designing with the PCM270x and PCM29xx devices, careful attention must be given to both the clocking and USB hardware configurations in order to ensure proper host to device communication.This applicatio
  • Audio Serial Interface Configurations for Audio Codecs
    PDF, 70 Кб, Файл опубликован: 22 сен 2010
    An audio serial interface (ASI) provides a means to transfer non-buffered audio data between processors and/or audio converters. These data are typically encoded in PCM twos complement format, although other format variations may be possible to achieve companding for lower data rate transfers. Audio converters based on the delta-sigma (О”ОЈ) architecture require an internal master clock
  • Out-of-Band Noise Measurement Issues for Audio Codecs
    PDF, 145 Кб, Файл опубликован: 6 дек 2006
Серия: LM4549B (2)
  • Semiconductors> Audio> Audio Converters> Audio CODEC
На английском языке: Datasheet Texas Instruments LM4549B
