Datasheet Texas Instruments LM4911 — Даташит
Серия | LM4911 |
Stereo 40mW Low Noise Headphone Amplifier with Selectable Capacitive Coupled or OCL Output
LM4911/911Q Stereo 40mW Low Noise HP Amp w/Selectable Cap Coupled or OCL Out datasheet
PDF, 1.8 Мб, Версия: M, Файл опубликован: 8 июн 2011
Купить LM4911 на РадиоЛоцман.Цены — от 27 до 211 ₽ 26 предложений от 20 поставщиков Stereo 40mW Low Noise Headphone Amplifier with Selectable Capacitive Coupled or OCL Output | |||
LM4911LD/NOPB Texas Instruments | 27 ₽ | ||
LM4911LD/NOPB Texas Instruments | 28 ₽ | ||
LM4911QMMX/NOPB Texas Instruments | по запросу | ||
LM4911 Texas Instruments | по запросу |
LM4911MM/NOPB | |
Статус продукта | В производстве |
LM4911MM/NOPB | |
N | 1 |
Pin | 10 |
Package Type | DGS |
Industry STD Term | VSSOP |
JEDEC Code | S-PDSO-G |
Package QTY | 1000 |
Carrier | LARGE T&R |
Маркировка | GA3 |
Width (мм) | 3 |
Length (мм) | 3 |
Thickness (мм) | 1.02 |
Pitch (мм) | .5 |
Max Height (мм) | 1.07 |
Mechanical Data | Скачать |
Parameters / Models | LM4911MM/NOPB |
Analog Supply (V), Max | 2 |
Архитектура | Class-AB |
Headphone Channels | Stereo |
Iq per channel(Typ), мА | 1 |
Load(Min), ohms | 16 |
Рабочий диапазон температур, C | от -40 до 85 |
Выходная мощность, W | 0.04 |
PSRR, дБ | 65 |
Package Group | VSSOP |
Package Size: mm2:W x L, PKG | 10VSSOP: 15 mm2: 4.9 x 3(VSSOP) |
Rating | Catalog |
Shutdown Current (ISD), uA | 0.1 |
Volume Control | No |
LM4911MM/NOPB | |
- Guidelines for Measuring Audio Power Amplifier PerformancePDF, 765 Кб, Файл опубликован: 30 окт 2001
This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply. - AN-1849 An Audio Amplifier Power Supply Design (Rev. B)PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs.
Серия: LM4911 (1)
- Semiconductors> Audio> Low-Power Audio Amplifiers ( Headphone Amplifier
