Datasheet Texas Instruments LP2996AMRX/NOPB — Даташит
Серия | LP2996A |
Модель | LP2996AMRX/NOPB |
Стабилизатор нагрузки DDR 1,5 А с контактом отключения 8-SO PowerPAD 0–125
LP2996A DDR Termination Regulator datasheet
PDF, 2.5 Мб, Файл опубликован: 27 июн 2014
Купить LP2996AMRX/NOPB на РадиоЛоцман.Цены — от 49 до 244 ₽ 17 предложений от 10 поставщиков Standard Regulator 1.5A 8Pin HSOP EP T/R | |||
LP2996AMRX/NOPB Texas Instruments | 49 ₽ | ||
LP2996AMRX/NOPB Texas Instruments | 67 ₽ | ||
LP2996AMRX/NOPB Texas Instruments | от 244 ₽ | ||
LP2996AMRX/NOPB Texas Instruments | по запросу |
Pin | 8 | 8 |
Package Type | DDA | DDA |
Industry STD Term | HSOIC | HSOIC |
Package QTY | 2500 | 2500 |
Carrier | LARGE T&R | LARGE T&R |
Маркировка | AMR | LP2996 |
Width (мм) | 3.9 | 3.9 |
Length (мм) | 4.89 | 4.89 |
Thickness (мм) | 1.48 | 1.48 |
Pitch (мм) | 1.27 | 1.27 |
Max Height (мм) | 1.7 | 1.7 |
Control Mode | N/A |
DDR Memory Type | DDR,DDR2,DDR3,DDR3L |
Iout VTT(Max) | 1.5 A |
Iq(Typ) | 0.32 мА |
Рабочий диапазон температур | от 0 до 125 C |
Output | VREF,VTT |
Package Group | SO PowerPAD |
Package Size: mm2:W x L | 8SO PowerPAD: 29 mm2: 6 x 4.9(SO PowerPAD) PKG |
Rating | Catalog |
Regulator Type | Linear Regulator |
Special Features | Shutdown Pin for S3 |
Vin Bias(Max) | 5.5 В |
Vin Bias(Min) | 2.2 В |
Vin(Max) | 5.5 В |
Vin(Min) | 1.35 В |
Vout VTT(Min) | 0.677 В |
- Evaluation Modules & Boards: LP2998EVAL
Evaluation Board for the LP2998
- Limiting DDR Termination Regulators’ Inrush CurrentPDF, 772 Кб, Файл опубликован: 23 авг 2016
The output voltage of DDR termination regulators tends to rise quickly after their VDDQ line is enabled. Most DDR terminators are specifically designed for fast start-up. They also require bulky output capacitors for a stable output voltage. This often results in a significant inrush current from DDR terminator voltage supply to charge the output capacitors and to provide curre
Серия: LP2996A (3)
- LP2996AMR/NOPB LP2996AMRE/NOPB LP2996AMRX/NOPB
- Semiconductors > Power Management > DDR Memory Power Solutions
