Datasheet Intersil ISL94203 — Даташит
Производитель | Intersil |
Серия | ISL94203 |
3-to-8 Cell Li-ion Battery Pack Monitor
Купить ISL94203 на РадиоЛоцман.Цены — от 197 до 1 651 ₽ 23 предложений от 13 поставщиков ISL94203IRTZ 3-to-8 Cell Li-ion Battery Pack Monitor, 48L 6x, TAPE & REEL PACK, | |||
ISL94203IRTZ-T Intersil | 197 ₽ | ||
ISL94203IRTZ-T Intersil | 198 ₽ | ||
ISL94203IRTZ-T7 Renesas | от 1 651 ₽ | ||
ISL94203IRTZ-T Intersil | по запросу |
ISL94203IRTZ | ISL94203IRTZ-T | ISL94203IRTZ-T7 | ISL94203IRTZ-T7A | |
N | 1 | 2 | 3 | 4 |
Корпус | 48Ld TQFN (6x6mm) | 48Ld TQFN (6x6mm) | 48Ld TQFN (6x6mm) | 48Ld TQFN (6x6mm) |
Parameters / Models | ISL94203IRTZ | ISL94203IRTZ-T | ISL94203IRTZ-T7 | ISL94203IRTZ-T7A |
# Series Cells | 3 to 8 Cells | 3 to 8 Cells | 3 to 8 Cells | 3 to 8 Cells |
Absolute Cell Voltage Measurement Accuracy | 15mV Max (0°C to 60°C) | 15mV Max (0°C to 60°C) | 15mV Max (0°C to 60°C) | 15mV Max (0°C to 60°C) |
Cell Balancing | External (Built-in FET Drivers) | External (Built-in FET Drivers) | External (Built-in FET Drivers) | External (Built-in FET Drivers) |
Communication Interface | I2C | I2C | I2C | I2C |
Description | 3-to-8 Cell Li-ion Battery Pack Monitor | 3-to-8 Cell Li-ion Battery Pack Monitor | 3-to-8 Cell Li-ion Battery Pack Monitor | 3-to-8 Cell Li-ion Battery Pack Monitor |
IS (max) | 370 μA | 370 μA | 370 μA | 370 μA |
Implementation | Pack | Pack | Pack | Pack |
Integrated Charge/Discharge FET Drive | Yes | Yes | Yes | Yes |
Integrated Current Sense/Detection | Yes (High Side Measurement) | Yes (High Side Measurement) | Yes (High Side Measurement) | Yes (High Side Measurement) |
Integrated Regulator Output/Reference Output | 2.5V / 1.8V | 2.5V / 1.8V | 2.5V / 1.8V | 2.5V / 1.8V |
Integrated Temperature Sense | Yes | Yes | Yes | Yes |
Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Pack Voltage | 4V to 36V | 4V to 36V | 4V to 36V | 4V to 36V |
Peak Temp | 260°C | 260°C | 260°C | 260°C |
Qualification Level | Standard | Standard | Standard | Standard |
SHDN ICC | (max) 1 μA | (max) 1 μA | (max) 1 μA | (max) 1 μA |
Special Features | Stand Alone operation or with External μC | Provides Diagnostic Info | Robust Hot Plug Performance | Fast Scan Rate of 100μs/Cell | Stand Alone operation or with External μC | Provides Diagnostic Info | Robust Hot Plug Performance | Fast Scan Rate of 100μs/Cell | Stand Alone operation or with External μC | Provides Diagnostic Info | Robust Hot Plug Performance | Fast Scan Rate of 100μs/Cell | Stand Alone operation or with External μC | Provides Diagnostic Info | Robust Hot Plug Performance | Fast Scan Rate of 100μs/Cell |
RoHS | Совместим | Совместим | Совместим | Совместим |
Серия: ISL94203 (4)
- Power Management > Battery Management Systems > Cell Balancing and Safety
