Datasheet Texas Instruments OPA140A-DIE — Даташит
СерияOPA140A-DIE
High-Precision, Low-Noise, Rail-to-Rail Output, 11MHz JFET Op Amp
High-Precision, Low-Noise, Rail-to-Rail Output, 11MHz JFET Operational Amplifier datasheet
PDF, 99 Кб, Версия: B, Файл опубликован: 27 мар 2012
AliExpress
OPA140AIDR OPA140AID OPA140A OPA140 SOP8 Чипсет 100% новый и оригинальный детский151 ₽
OPA140ATDD1OPA140ATDD2
N12
Package TypeTDTD
Package QTY25210
RoHSSee ti.comSee ti.com
  • Compensate Transimpedance Amplifiers Intuitively (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 30 мар 2005
    Transimpedance amplifiers are used to convert low-level photodiode currents to usable voltage signals. All too often, the amplifiers have to be empirically compensated to operate properly. The problem can be easily understood if one looks at all the elements involved.
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
Серия: OPA140A-DIE (2)
  • Semiconductors> Amplifiers> Operational Amplifiers (Op Amps)> Precision Op Amps
На английском языке: Datasheet Texas Instruments OPA140A-DIE
