Datasheet Texas Instruments OPA170-DIE — Даташит
Серия | OPA170-DIE |
Single-Supply, Low-Power Operational Amplifier
Single-Supply, Low-Power Operational Amplifier datasheet
PDF, 60 Кб, Файл опубликован: 19 фев 2013
Купить OPA170 на РадиоЛоцман.Цены — от 28 до 247 ₽ 50 предложений от 26 поставщиков Усилители.Тип: Прецизионный операционный усилитель серии OPA170Количество: каналов - 1; вход/ выход - Rail-to-RailВыходной ток: на канал - 17 мАСкорость: SR -... | |||
OPA170AIDBVR Texas Instruments | 28 ₽ | ||
OPA170AIDR Texas Instruments | 32 ₽ | ||
OPA170AID Texas Instruments | по запросу | ||
OPA170AIDBVT Texas Instruments | по запросу |
OPA170TDA1 | OPA170TDA2 | |
Статус продукта | В производстве | В производстве |
Доступность образцов у производителя | Нет | Нет |
N | 1 | 2 |
Package Type | TD | TD |
Package QTY | 400 | 10 |
RoHS | See ti.com | See ti.com |
- Compensate Transimpedance Amplifiers Intuitively (Rev. A)PDF, 69 Кб, Версия: A, Файл опубликован: 30 мар 2005
Transimpedance amplifiers are used to convert low-level photodiode currents to usable voltage signals. All too often, the amplifiers have to be empirically compensated to operate properly. The problem can be easily understood if one looks at all the elements involved. - Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA170-DIE (2)
- Semiconductors> Space & High Reliability> Amplifier> Operational Amplifiers
