Datasheet Texas Instruments OPA2170-Q1 — Даташит
Серия | OPA2170-Q1 |
Automotive 36V, microPower, Rail-to-Rail Output, General Purpose Op Amp in MicroPackages
OPAx170-Q1 36-V, Single-Supply, Low-Power, Automotive-Grade Operational Amplifiers datasheet
PDF, 1.3 Мб, Версия: A, Файл опубликован: 24 мар 2017
Купить OPA2170 на РадиоЛоцман.Цены — от 41 до 282 ₽ 40 предложений от 23 поставщиков TEXAS INSTRUMENTS OPA2170AIDR Operational Amplifier, Rail-to-Rail, 2 Amplifier, 1.2MHz, 0.4V/µs, 2.7V to 36V, ± 1.35V to ± 18V | |||
OPA2170AIDR Texas Instruments | 41 ₽ | ||
OPA2170AIDGKR Texas Instruments | от 42 ₽ | ||
OPA2170AIDSGR Texas Instruments | от 282 ₽ | ||
OPA2170AIDGK Texas Instruments | по запросу |
OPA2170AQDGKRQ1 | |
Статус продукта | В производстве |
OPA2170AQDGKRQ1 | |
N | 1 |
Pin | 8 |
Package Type | DGK |
Industry STD Term | VSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | 2170 |
Width (мм) | 3 |
Length (мм) | 3 |
Thickness (мм) | .97 |
Pitch (мм) | .65 |
Max Height (мм) | 1.07 |
Mechanical Data | Скачать |
Parameters / Models | OPA2170AQDGKRQ1 |
Additional Features | EMI Hardened |
Архитектура | CMOS |
CMRR(Typ), дБ | 120 |
GBW(Typ), МГц | 1.2 |
Input Bias Current(Max), pA | 15 |
Iq per channel(Typ), мА | 0.1 |
Количество каналов | 2 |
Offset Drift(Typ), uV/C | 0.3 |
Рабочий диапазон температур, C | от -40 до 125 |
Output Current(Typ), мА | 17 |
Package Group | VSSOP |
Package Size: mm2:W x L, PKG | 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) |
Rail-to-Rail | In to V-,Out |
Rating | Automotive |
Slew Rate(Typ), V/us | 0.4 |
Total Supply Voltage(Max), +5V=5, +/-5V=10 | 36 |
Total Supply Voltage(Min), +5V=5, +/-5V=10 | 2.7 |
Vn at 1kHz(Typ), нВ/rtГц | 19 |
Vos (Offset Voltage @ 25C)(Max), мВ | 1.8 |
OPA2170AQDGKRQ1 | |
- Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA2170-Q1 (1)
- Semiconductors> Amplifiers> Operational Amplifiers (Op Amps)> Precision Op Amps
