Datasheet Texas Instruments OPA2348-HIREL — Даташит
Серия | OPA2348-HIREL |
1MHz, 45uA, RRIO, Dual Op Amp
1 MHz, 45-uA, CMOS, Rail-to-Rail Opamp datasheet
PDF, 206 Кб, Файл опубликован: 24 ноя 2009
Купить OPA2348 на РадиоЛоцман.Цены — от 15 до 713 ₽ 56 предложений от 31 поставщиков Операционный усилитель, 2 Усилителя, 1 МГц, 0.5 В/мкс, 2.1В до 5.5В, SOIC, 8 вывод(-ов) | |||
OPA2348AIDR Texas Instruments | от 15 ₽ | ||
OPA2348AIDR Texas Instruments | 16 ₽ | ||
OPA2348AIDGKR Texas Instruments | от 111 ₽ | ||
OPA2348AIDR | по запросу |
OPA2348CKGD4 | |
Статус продукта | В производстве |
OPA2348CKGD4 | |
N | 1 |
Package Type | KGD |
Package QTY | 25522 |
Parameters / Models | OPA2348CKGD4 |
Additional Features | N/A |
Архитектура | CMOS |
CMRR(Min), дБ | 70 |
CMRR(Typ), дБ | 82 |
GBW(Typ), МГц | 1 |
IIB(Max), pA | 10 |
Iq per channel(Max), мА | 0.065 |
Iq per channel(Typ), мА | 0.045 |
Количество каналов | 2 |
Offset Drift(Typ), uV/C | 4 |
Рабочий диапазон температур, C | от 0 до 70 |
Output Current(Typ), мА | 10 |
Rail-to-Rail | In,Out |
Rating | Catalog |
Slew Rate(Typ), V/us | 0.5 |
Total Supply Voltage(Max), +5V=5, +/-5V=10 | 5.5 |
Total Supply Voltage(Min), +5V=5, +/-5V=10 | 2.1 |
Vn at 1kHz(Typ), нВ/rtГц | 35 |
Vos (Offset Voltage @ 25C)(Max), мВ | 5 |
OPA2348CKGD4 | |
RoHS | See ti.com |
- Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA2348-HIREL (1)
- Semiconductors> Space & High Reliability> Amplifier> Operational Amplifiers
