Datasheet Texas Instruments OPA2836QDGKRQ1 — Даташит
Серия | OPA2836-Q1 |
Модель | OPA2836QDGKRQ1 |
Automotive, Dual, Very Low Power, Rail to Rail output, VFB Op Amp 8-VSSOP -40 to 125
OPA2836-Q1 Very-Low Power, Rail-to-Rail Out, Negative-Rail In, Voltage-Feedback Operational Amplifier datasheet
PDF, 1.9 Мб, Файл опубликован: 6 дек 2016
Купить OPA2836QDGKRQ1 на РадиоЛоцман.Цены — от 193 до 1 337 ₽ 14 предложений от 10 поставщиков Automotive, Dual, Very Low Power, Rail to Rail output, VFB Op Amp 8-VSSOP -40℃ to 125℃ | |||
OPA2836QDGKRQ1 Texas Instruments | 193 ₽ | ||
OPA2836QDGKRQ1 Texas Instruments | 204 ₽ | ||
OPA2836QDGKRQ1 Texas Instruments | по запросу | ||
Pin | 8 |
Package Type | DGK |
Industry STD Term | VSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | 2836Q |
Width (мм) | 3 |
Length (мм) | 3 |
Thickness (мм) | .97 |
Pitch (мм) | .65 |
Max Height (мм) | 1.07 |
Mechanical Data | Скачать |
2nd Harmonic | 85 dBc |
3rd Harmonic | 79 dBc |
@ MHz | 1 |
Acl, min spec gain | 1 V/V |
Архитектура | Bipolar,Voltage FB |
BW @ Acl | 205 МГц |
CMRR(Typ) | 116 дБ |
Input Bias Current(Max) | 1000000 pA |
Iq per channel(Typ) | 1 мА |
Количество каналов | 2 |
Output Current(Typ) | 50 мА |
Package Group | VSSOP |
Package Size: mm2:W x L | 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG |
Rail-to-Rail | In to V-,Out |
Rating | Automotive |
Slew Rate(Typ) | 560 V/us |
Total Supply Voltage(Max) | 5.5 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 2.5 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 5 нВ/rtГц |
Vn at Flatband(Typ) | 4.6 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 0.4 мВ |
- Evaluation Modules & Boards: OPA2836IDGSEVM
OPA2836 Evaluation Module for VSSOP/MSOP Package
Статус продукта: В производстве (Рекомендуется для новых разработок) - Evaluation Modules & Boards: ADS7945EVM-PDK
ADS7945 Performance Demonstration Kit
- Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA2836-Q1 (1)
- OPA2836QDGKRQ1
- Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > High-Speed Op Amps (>=50MHz)
