Datasheet Texas Instruments OPA361-Q1 — Даташит
Серия | OPA361-Q1 |
Automotive Catalog 3V Video Amplifier with Internal Gain and Filter
3-V Video Amplifier with Internal Gain and Filter in SC70 datasheet
PDF, 905 Кб, Файл опубликован: 14 мар 2011
Купить OPA361 на РадиоЛоцман.Цены — от 17 до 79 ₽ 31 предложений от 20 поставщиков TEXAS INSTRUMENTS OPA361AIDCKTG4 Video Amplifier, 1 Amplifiers, 9 MHz, -40 C, 125 C, 80 mA | |||
OPA361AIDCKTG4 Texas Instruments | от 17 ₽ | ||
OPA361AIDCKT Texas Instruments | 22 ₽ | ||
OPA361AIDCKRG4 Texas Instruments | по запросу | ||
OPA361AIDCKT Texas Instruments | по запросу |
OPA361AQDCKRQ1 | |
Статус продукта | В производстве |
OPA361AQDCKRQ1 | |
N | 1 |
Pin | 6 |
Package Type | DCK |
Industry STD Term | SOT-SC70 |
JEDEC Code | R-PDSO-G |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | QXP |
Width (мм) | 1.25 |
Length (мм) | 2 |
Thickness (мм) | .9 |
Pitch (мм) | .65 |
Max Height (мм) | 1.1 |
Mechanical Data | Скачать |
Parameters / Models | OPA361AQDCKRQ1 |
Diff Gain, % | 1.2 |
Diff Phase, deg | 1.6 |
Количество каналов | 1 |
Рабочий диапазон температур, C | от -40 до 125 |
Output Current(Typ), мА | 80 |
Package Group | SC70 |
Package Size: mm2:W x L, PKG | 6SC70: 4 mm2: 2.1 x 2(SC70) |
Rating | Automotive |
Vs(Max), В | 3.6 |
Vs(Min), В | 2.5 |
OPA361AQDCKRQ1 | |
- Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA361-Q1 (1)
- Semiconductors> Amplifiers> Special Function Amplifiers> Video Amplifiers
