Datasheet Texas Instruments OPA615IDGSR — Даташит
Серия | OPA615 |
Модель | OPA615IDGSR |
Wide Bandwidth, DC Restoration Circuit 10-VSSOP -40 to 85
Wide Bandwidth, DC Restoration Circuit datasheet
PDF, 1.2 Мб, Версия: E, Файл опубликован: 28 сен 2009
Купить OPA615IDGSR на РадиоЛоцман.Цены — от 402 до 1 396 ₽ 17 предложений от 13 поставщиков Wide Bandwidth, DC Restoration Circuit 10-VSSOP -40℃ to 85℃ | |||
OPA615IDGSR Texas Instruments | 402 ₽ | ||
OPA615IDGSR Texas Instruments | 573 ₽ | ||
OPA615IDGSR Texas Instruments | 637 ₽ | ||
OPA615IDGSR Texas Instruments | по запросу |
Pin | 10 |
Package Type | DGS |
Industry STD Term | VSSOP |
JEDEC Code | S-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | BJT |
Width (мм) | 3 |
Length (мм) | 3 |
Thickness (мм) | 1.02 |
Pitch (мм) | .5 |
Max Height (мм) | 1.07 |
Mechanical Data | Скачать |
Acl, min spec gain | 1 V/V |
BW @ Acl | 710 МГц |
GBW(Typ) | 710 МГц |
IIB(Max) | 3000 нА |
Iq per channel(Max) | 13 мА |
Количество каналов | 1 |
Output Current(Typ) | 20 мА |
Package Group | VSSOP |
Package Size: mm2:W x L | 10VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG |
Slew Rate(Typ) | 2500 V/us |
Vn at Flatband(Typ) | 4.6 нВ/rtГц |
Vos(Max) | 40 мВ |
Vs(Max) | 12.4 В |
Vs(Min) | 8 В |
- Evaluation Modules & Boards: DEM-OPA-MSOP-1A
DEM-OPA-MSOP-1A
Статус продукта: В производстве (Рекомендуется для новых разработок) - Evaluation Modules & Boards: DEM-OPA-SO-1C
DEM-OPA-SO-1C
- Demystifying the Operational Transconductance Amplifier (Rev. A)PDF, 259 Кб, Версия: A, Файл опубликован: 16 апр 2013
Operational transconductance amplifiers (OTAs) are often among the least understood analog components. However, these devices serve a very useful function that is being implemented on a regular basis in many integrated circuits as an element for more advanced purposes; the current feedback amplifier is among the most prominent example. The purpose of this application report is to show how this bui - Measuring op-amp settling time by using sample-and-hold techniquePDF, 191 Кб, Файл опубликован: 31 янв 2012
- 1Q 2012 Issue Analog Applications JournalPDF, 2.4 Мб, Файл опубликован: 31 янв 2012
- Noise Analysis for High Speed Op Amps (Rev. A)PDF, 256 Кб, Версия: A, Файл опубликован: 17 янв 2005
Серия: OPA615 (5)
- OPA615ID OPA615IDGSR OPA615IDGST OPA615IDR OPA615IDRG4
- Semiconductors > Amplifiers > Special Function Amplifiers > Transconductance Amplifiers
