Datasheet Texas Instruments OPA860IDG4 — Даташит
Серия | OPA860 |
Модель | OPA860IDG4 |
Wide Bandwidth Operational Transconductance Amplifier and Buffer 8-SOIC -40 to 85
Wide-Bandwidth, Operational Transconductance Amplifier (OTA) and Buffer datasheet
PDF, 797 Кб, Версия: C, Файл опубликован: 28 авг 2008
Купить OPA860IDG4 на РадиоЛоцман.Цены — от 253 до 1 137 920 ₽ 10 предложений от 10 поставщиков Wide Bandwidth Operational Transconductance Amplifier and Buffer 8-SOIC -40℃ to 85℃ | |||
OPA860IDG4 Texas Instruments | 253 ₽ | ||
OPA860IDG4 Texas Instruments | 379 ₽ | ||
OPA860IDG4 Texas Instruments | 570 ₽ | ||
OPA860IDG4 Texas Instruments | по запросу |
Pin | 8 | 8 |
Package Type | D | D |
Industry STD Term | SOIC | SOIC |
Package QTY | 75 | 75 |
Carrier | TUBE | TUBE |
Маркировка | OPA | 860 |
Width (мм) | 3.91 | 3.91 |
Length (мм) | 4.9 | 4.9 |
Thickness (мм) | 1.58 | 1.58 |
Pitch (мм) | 1.27 | 1.27 |
Max Height (мм) | 1.75 | 1.75 |
Acl, min spec gain | 1 V/V |
BW @ Acl | 470 МГц |
GBW(Typ) | 470 МГц |
IIB(Max) | 5000 нА |
Iq per channel(Max) | 11.2 мА |
Количество каналов | 1 |
Output Current(Typ) | 15 мА |
Package Group | SOIC |
Package Size: mm2:W x L | 8SOIC: 29 mm2: 6 x 4.9(SOIC) PKG |
Slew Rate(Typ) | 3500 V/us |
Vn at Flatband(Typ) | 2.4 нВ/rtГц |
Vos(Max) | 12 мВ |
Vs(Max) | 13 В |
Vs(Min) | 2 В |
- Evaluation Modules & Boards: DEM-OTA-SO-1A
Unpopulated PCB Compatible w/Wide Bandwidth Transconductance Op Amps in 8-lead SOIC (D) Pkg
- Demystifying the Operational Transconductance Amplifier (Rev. A)PDF, 259 Кб, Версия: A, Файл опубликован: 16 апр 2013
Operational transconductance amplifiers (OTAs) are often among the least understood analog components. However, these devices serve a very useful function that is being implemented on a regular basis in many integrated circuits as an element for more advanced purposes; the current feedback amplifier is among the most prominent example. The purpose of this application report is to show how this bui - Noise Analysis for High Speed Op Amps (Rev. A)PDF, 256 Кб, Версия: A, Файл опубликован: 17 янв 2005
Серия: OPA860 (4)
- OPA860ID OPA860IDG4 OPA860IDR OPA860IDRG4
- Semiconductors > Amplifiers > Special Function Amplifiers > Transconductance Amplifiers
