Datasheet Texas Instruments PCM1681TPWPQ1 — Даташит
Серия | PCM1681-Q1 |
Модель | PCM1681TPWPQ1 |
105dB SNR 8-Channel Audio DAC (Automotive Catalog) 28-HTSSOP -40 to 105
PCM1681 24-Bit, 192-kHz Sampling, Enhanced Multilevel Delta-Sigma, Eight-Channel Audio Digital-to-Analog Converter datasheet
PDF, 1.4 Мб, Версия: C, Файл опубликован: 31 июл 2015
Купить PCM1681TPWPQ1 на РадиоЛоцман.Цены — от 136 до 668 ₽ 20 предложений от 13 поставщиков new in stock for immediate delivery | |||
PCM1681TPWPQ1 Texas Instruments | 136 ₽ | ||
PCM1681TPWPQ1 Texas Instruments | 222 ₽ | ||
PCM1681TPWPQ1 Texas Instruments | 374 ₽ | ||
PCM1681TPWPQ1 Texas Instruments | 375 ₽ |
Pin | 28 |
Package Type | PWP |
Industry STD Term | HTSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 50 |
Carrier | TUBE |
Маркировка | PCM1681TQ1 |
Width (мм) | 4.4 |
Length (мм) | 9.7 |
Thickness (мм) | 1 |
Pitch (мм) | .65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Analog Outputs | 8 |
Архитектура | Current Segment DAC |
Control Interface | SPI,I2C,H/W |
DAC Channels | 8 |
DAC SNR(Typ) | 105 дБ |
Package Size: mm2:W x L | 28HTSSOP: 62 mm2: 6.4 x 9.7(HTSSOP) PKG |
Разрешение | 24 Bits |
Sampling Rate(Max) | 200 kHz |
- THD+N Versus Frequency Characteristics and Spectra of the PCM1717/18/19/20/23/27PDF, 107 Кб, Файл опубликован: 27 сен 2000
The following application bulletin describes the theory and actual performance of THD+N versus frequency characteristics for the PCM1717 series which include on-chip digital filters. The contents of this article apply to the PCM1717 and other devices which use the same digital filter architecture and delta-sigma DAC, such as PCM1718, PCM1719, PCM1720, PCM1723, and PCM1727. - A Low Noise, Low Distortion Design for Antialiasing and Anti-Imaging FiltersPDF, 62 Кб, Файл опубликован: 27 сен 2000
In any digitizing system, antialiasing and anti-imaging filters are used to prevent the signal frequencies from folding back around the sample frequency and causing false (or alias) signals from appearing in the signal we are attempting to digitize. Very often, these filters must be very complex, high order analog filters in order to do their job effectively. - Dyamic Performance Testing of Digital Audio D/A ConvertersPDF, 145 Кб, Файл опубликован: 2 окт 2000
This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM1681-Q1 (2)
- PCM1681TPWPQ1 PCM1681TPWPRQ1
- Semiconductors > Audio > Audio Converters > Audio DAC
