Datasheet Texas Instruments PCM1728E — Даташит
Серия | PCM1728 |
Модель | PCM1728E |
106dB SNR Stereo DAC 28-SSOP
SoundPlus 24-Bit, 96kHz Sampling CMOS Delta-Sigma Digital/Analog Converter datasheet
PDF, 155 Кб, Файл опубликован: 27 сен 2000
Купить PCM1728E на РадиоЛоцман.Цены — от 305 до 1 310 ₽ 18 предложений от 14 поставщиков DAC 2CH Delta-Sigma 24Bit 28Pin SSOP Tube | |||
PCM1728E Texas Instruments | от 305 ₽ | ||
PCM1728E Texas Instruments | 448 ₽ | ||
PCM1728E Texas Instruments | 575 ₽ | ||
PCM1728E | по запросу |
Статус продукта | NRND (Не рекомендуется для новых разработок) |
Pin | 28 |
Package Type | DB |
Industry STD Term | SSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 47 |
Carrier | TUBE |
Маркировка | PCM1728E |
Width (мм) | 5.3 |
Length (мм) | 10.2 |
Thickness (мм) | 1.95 |
Pitch (мм) | .65 |
Max Height (мм) | 2 |
Mechanical Data | Скачать |
- Low Sampling Rate Operation SoundPlus Audio Data Converters and CODECsPDF, 291 Кб, Файл опубликован: 27 сен 2000
This application bulletin describes the operation and performance of Burr-Brown's PCM digital audio products when using low sampling frequencies. - Control Port And Reset Operation SoundPlus Audio Converters and CODECsPDF, 77 Кб, Файл опубликован: 27 сен 2000
This application bulletin provides operational details of the serial control port and reset functions for Burr-Brown digital audio data converters and CODECs. Specifically, this information applies to the PCM1716, PCM1717, PCM1719, PCM1720, PCM1723, PCM1727, PCM3000-series CODECs, and the PCM1800 A/D converter. - Dyamic Performance Testing of Digital Audio D/A ConvertersPDF, 145 Кб, Файл опубликован: 2 окт 2000
This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM1728 (3)
- PCM1728E PCM1728E/2K PCM1728EG4
- Semiconductors > Audio > Audio Converters > Audio DAC
