Datasheet Texas Instruments PCM2705DB — Даташит
Серия | PCM2705 |
Модель | PCM2705DB |
98dB SNR Stereo USB2.0 FS DAC with line-out and S/PDIF output, Bus/Self-powered (S/W Control) 28-SSOP -25 to 85
Stereo Audio DAC With USB Interface Single-Ended Headphone Output and S/PDIF Out datasheet
PDF, 1.2 Мб, Версия: F, Файл опубликован: 15 янв 2009
Купить PCM2705DB на РадиоЛоцман.Цены — от 256 до 1 776 ₽ 21 предложений от 14 поставщиков TEXAS INSTRUMENTS PCM2705DB Digital to Analog Converter, 16Bit, 48KSPS, Serial, 3V to 3.6V, 4.35V to 5.25V, SSOP, 28Pins | |||
PCM2705DB Texas Instruments | 256 ₽ | ||
PCM2705DB Texas Instruments | 295 ₽ | ||
PCM2705DB Texas Instruments | от 329 ₽ | ||
PCM2705DB Texas Instruments | 389 ₽ |
Статус продукта | NRND (Не рекомендуется для новых разработок) |
Pin | 28 |
Package Type | DB |
Industry STD Term | SSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 50 |
Carrier | TUBE |
Маркировка | PCM2705 |
Width (мм) | 5.3 |
Length (мм) | 10.2 |
Thickness (мм) | 1.95 |
Pitch (мм) | .65 |
Max Height (мм) | 2 |
Mechanical Data | Скачать |
- Differences between PCM270x and PCM270xCPDF, 78 Кб, Файл опубликован: 16 авг 2011
This document presents the major differences between the PCM270x and PCM270xC audio data converters. - Solving Enumeration Errors in USB Audio DAC and CODEC DesignsPDF, 157 Кб, Файл опубликован: 30 окт 2009
TI’s portfolio of audio digital-to-analog converters (DACs) and coder/decoders (codecs) with integrated USB interfaces offers an excellent building block for any streaming USB audio system. When designing with the PCM270x and PCM29xx devices, careful attention must be given to both the clocking and USB hardware configurations in order to ensure proper host to device communication.This applicatio - Dyamic Performance Testing of Digital Audio D/A ConvertersPDF, 145 Кб, Файл опубликован: 2 окт 2000
This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM2705 (4)
- PCM2705DB PCM2705DBG4 PCM2705DBR PCM2705DBRG4
- Semiconductors > Audio > Audio Converters > Audio USB Converter
