KEEN SIDE успешно заменяет аналогичные продукты таких известных брендов, как Phoenix Contact, Weidmueller, Degson, Winstar, Hsuan Mao, KLS, G-NOR, Mean Well и др.
Datasheet Texas Instruments PCM5100A — Даташит
СерияPCM5100A
2VRMS DirectPathв„ў, 100dB Audio Stereo DAC with 32-bit, 384kHz PCM Interface
PCM510xA 2.1 VRMS, 112/106/100 dB Audio Stereo DAC with PLL and 32-bit, 384 kHz PCM Interface datasheet
PDF, 1.5 Мб, Версия: C, Файл опубликован: 6 май 2015
Acme Chip
PCM5100/A
PCM5100APWPCM5100APWR
Доступность образцов у производителяДаНет
N12
Pin2020
Package TypePWPW
Industry STD TermTSSOPTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY702000
CarrierTUBELARGE T&R
МаркировкаPCM5100APCM5100A
Width (мм)4.44.4
Length (мм)6.56.5
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
Parameters / ModelsPCM5100APW
PCM5100APW
PCM5100APWR
PCM5100APWR
Analog Outputs22
АрхитектураDelta Sigma with line driverDelta Sigma with line driver
Control InterfaceH/WH/W
DAC Channels22
DAC SNR(Typ), дБ100100
Package Size: mm2:W x L, PKG20TSSOP: 42 mm2: 6.4 x 6.5(TSSOP)20TSSOP: 42 mm2: 6.4 x 6.5(TSSOP)
Разрешение, Bits3232
Sampling Rate(Max), kHz384384
RoHSСовместимСовместим
  • A Low Noise, Low Distortion Design for Antialiasing and Anti-Imaging Filters
    PDF, 62 Кб, Файл опубликован: 27 сен 2000
    In any digitizing system, antialiasing and anti-imaging filters are used to prevent the signal frequencies from folding back around the sample frequency and causing false (or alias) signals from appearing in the signal we are attempting to digitize. Very often, these filters must be very complex, high order analog filters in order to do their job effectively.
  • Dyamic Performance Testing of Digital Audio D/A Converters
    PDF, 145 Кб, Файл опубликован: 2 окт 2000
    This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM5100A (2)
  • Semiconductors> Audio> Audio Converters> Audio DAC
На английском языке: Datasheet Texas Instruments PCM5100A
