Datasheet Texas Instruments PCM5121 — Даташит
Серия | PCM5121 |
2V RMS DIRECTPATH 106dB Audio Stereo DAC with PCM interface and fixed Audio processing
PCM512x 2-VRMS DirectPathв„ў, 112/106-dB Audio Stereo DAC With 32-bit, 384-kHz PCM Interface datasheet
PDF, 2.3 Мб, Версия: B, Файл опубликован: 13 янв 2016
Купить PCM5121 на РадиоЛоцман.Цены — от 106 до 428 ₽ 21 предложений от 14 поставщиков Микросхема: IC DAC 16/24/32BIT 384K 28TSSOP | |||
PCM5121PWR Texas Instruments | от 106 ₽ | ||
PCM5121PWR Texas Instruments | 111 ₽ | ||
PCM5121PW Texas Instruments | по запросу | ||
PCM5121PW | PCM5121PWR | |
Статус продукта | В производстве | В производстве |
Доступность образцов у производителя | Нет | Да |
N | 1 | 2 |
Pin | 28 | 28 |
Package Type | PW | PW |
Industry STD Term | TSSOP | TSSOP |
Package QTY | 50 | 2000 |
Carrier | TUBE | LARGE T&R |
Маркировка | PCM5121 | PCM5121 |
Width (мм) | 4.4 | 4.4 |
Length (мм) | 9.7 | 9.7 |
Thickness (мм) | 1 | 1 |
Pitch (мм) | .65 | .65 |
Max Height (мм) | 1.2 | 1.2 |
Parameters / Models | PCM5121PW | PCM5121PWR |
Analog Outputs | 2 | 2 |
Архитектура | Delta Sigma with line driver | Delta Sigma with line driver |
Control Interface | I2C,SPI,H/W | I2C,SPI,H/W |
DAC Channels | 2 | 2 |
DAC SNR(Typ), дБ | 106 | 106 |
Package Size: mm2:W x L, PKG | 28TSSOP: 62 mm2: 6.4 x 9.7(TSSOP) | 28TSSOP: 62 mm2: 6.4 x 9.7(TSSOP) |
Разрешение, Bits | 32 | 32 |
Sampling Rate(Max), kHz | 384 | 384 |
- A Low Noise, Low Distortion Design for Antialiasing and Anti-Imaging FiltersPDF, 62 Кб, Файл опубликован: 27 сен 2000
In any digitizing system, antialiasing and anti-imaging filters are used to prevent the signal frequencies from folding back around the sample frequency and causing false (or alias) signals from appearing in the signal we are attempting to digitize. Very often, these filters must be very complex, high order analog filters in order to do their job effectively. - Dyamic Performance Testing of Digital Audio D/A ConvertersPDF, 145 Кб, Файл опубликован: 2 окт 2000
This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM5121 (2)
- Semiconductors> Audio> Audio Converters> Audio DAC
