Datasheet Texas Instruments PMS430E325 — Даташит
Серия | PMS430E325 |
16-Bit Ultra-Low-Power Microcontroller,16kB EPROM, 512B RAM, 14 bit ADC, 84 segment LCD
MSP430C32x, MSP430x32xA Mixed Signal Microcontroller (Rev. B)
PDF, 465 Кб, Версия: B, Файл опубликован: 14 мар 2000
Купить PMS430E325 на РадиоЛоцман.Цены — от 75 до 11 735 ₽ 12 предложений от 9 поставщиков MSP430 Microcontroller IC 16-Bit 8MHz 16KB (16K x 8) EPROM, UV 68-JLCC (23.94x23.94) | |||
PMS430E325AFZ Texas Instruments | 75 ₽ | ||
PMS430E325AFZ Texas Instruments | от 1 174 ₽ | ||
PMS430E325AFZ Texas Instruments | 9 763 ₽ | ||
PMS430E325AFZ Texas Instruments | по запросу |
PMS430E325FZ | |
Статус продукта | Снят с производства |
PMS430E325FZ | |
N | 1 |
Pin | 68 |
Package Type | FZ |
Width (мм) | 23.98 |
Length (мм) | 23.98 |
Thickness (мм) | 3.3 |
Mechanical Data | Скачать |
PMS430E325FZ | |
RoHS | Не совместим |
- Architecture and Function of the MSP430 14-Bit ADCPDF, 212 Кб, Файл опубликован: 21 июн 1999
This application report describes the architecture and function of the 14-bit analog-to-digital converter (ADC) of the MSP430 family. The principles of the ADC are explained and software examples are given. The report also explains the function of all hardware registers in the ADC. The References section at the end of the report lists related application reports in the MSP430 14-bit ADC series. - Non-Linear Improvement of the MSP430 14-Bit ADC CharacteristicPDF, 371 Кб, Файл опубликован: 22 июн 1999
This application report shows nonlinear methods--with quadratic and cubic equations--to improve the accuracy of the 14-bit analog-to-digital converter (ADC) of the MSP430 family. The methods used differ in RAM and ROM requirements, calculation speed, achievable improvement, and complexity. The influence of the restricted calculation accuracy for 8-bit coefficients is compared to the accuracy of fl - Application Basics for the MSP430 14-Bit ADCPDF, 220 Кб, Файл опубликован: 22 июн 1999
This application report gives a detailed overview of several applications for the 14-bit analog-to-digital converter (ADC) of the MSP430 family. Proven software examples and basic circuitry are shown and explained. The 12-bit mode is also considered, when possible. The References section at the end of the report lists related application reports in the MSP430 14-bit ADC series. - Additive Improvement of the MSP430 14-Bit ADC CharacteristicPDF, 364 Кб, Файл опубликован: 22 июн 1999
This application report shows different simple methods to improve the accuracy of the 14-bit analog-to-digital converter of the MSP430 family. They all use only addition for the correction of the analog-to-digital converter characteristic. Different correction methods are explained--all without the need for multiplication--which makes them usable for real time systems like electronic electricity m - Linear Improvement of the MSP430 14-Bit ADC CharacteristicPDF, 405 Кб, Файл опубликован: 21 июн 1999
This application report shows different linear methods to improve the accuracy of the 14-bit analog-to-digital converter (ADC) of the MSP430 family. Different correction methods are explained: some with monotonicity and some using linear regression. The methods used differ in RAM and ROM allocation, calculation speed, reachable improvement, and complexity. For all correction methods, proven, optim - Understanding the MSP430x325 14-Bit ADCPDF, 49 Кб, Файл опубликован: 30 апр 1999
This application report describes and explains techniques for using the MSP430x325 ADC in preset and auto range modes. - Implementing a UART Function with the 8-bit Interval Timer/CounterPDF, 80 Кб, Файл опубликован: 17 дек 1999
This application report describes the implementation of a hardware/software universal asynchronous receiver tranmitter (UART) function on the MSP430x31x, MSP430x32x, and MSP430x33x families of 16-bit RISC-like mixed-signal processors using the integrated 8-bit interval timer/counter (8-bit T/C). The UART function described in this report is half-duplex, event-driven, and supports an 8N1 protocol u
Серия: PMS430E325 (1)
- Semiconductors> Microcontrollers (MCU)> MSP430 ultra-low-power MCUs> 3 Series
