Datasheet Texas Instruments SM320F2801-EP — Даташит
СерияSM320F2801-EP
Enhanced Product Digital Signal Processors
Digital Signal Processors datasheet
PDF, 1.0 Мб, Версия: A, Файл опубликован: 8 фев 2007
SM320F2801-EP
SM320F2801PZMEPV62/06619-03XE
N12
Pin100100
Package TypePZPZ
Industry STD TermLQFPLQFP
JEDEC CodeS-PQFP-GS-PQFP-G
Package QTY9090
CarrierJEDEC TRAY (5+1)JEDEC TRAY (5+1)
Маркировка2801PZMEPSM320F
Width (мм)1414
Length (мм)1414
Thickness (мм)1.41.4
Pitch (мм).5.5
Max Height (мм)1.61.6
Parameters / ModelsSM320F2801PZMEP
SM320F2801PZMEP
V62/06619-03XE
V62/06619-03XE
ADC, Ch1616
Additional FeaturesSingle Zone Code Security,32-bit CPU Timers,Watchdog Timer,20 pin Oscillator,Military QualifiedSingle Zone Code Security,32-bit CPU Timers,Watchdog Timer,20 pin Oscillator,Military Qualified
Analog to Digital Converter, ADCADC12: 2-S/H, 6.25-MSPSADC12: 2-S/H, 6.25-MSPS
CAP22
CPUC28xC28x
Flash, KB3232
Тактовая частота, МГц100100
GPIO3535
High Resolution PWM, Ch33
I2C11
Рабочий диапазон температур, Cот -55 до 125от -55 до 125
Other Actuation FeaturesN/AN/A
Other Connectivity FeaturesCANCAN
Other Sensing FeaturesN/AN/A
PWM, Ch66
PWM Technology TypeType 0Type 0
Package GroupLQFPLQFP
Package Size: mm2:W x L, PKG100LQFP: 256 mm2: 16 x 16(LQFP)100LQFP: 256 mm2: 16 x 16(LQFP)
Processing AcceleratorsN/AN/A
QEP11
RAM, KB1212
RatingHiRel Enhanced ProductHiRel Enhanced Product
SPI22
Total Processing, MIPS100100
UART11
RoHSСовместимСовместим
  • TPS75005 Quick-Start Guide with C2000 Controllers
    PDF, 129 Кб, Файл опубликован: 17 янв 2012
    The TPS75005 is a complete power management solution for C2000 controllers from Texas Instruments. This document illustrates how to attach the TPS75005 to a C2000 controller.
Серия: SM320F2801-EP (2)
  • Semiconductors> Space & High Reliability> Microcontroller> Performance MCU> Real Time Control MCUs> Fixed-points F280x/1x DSPs
На английском языке: Datasheet Texas Instruments SM320F2801-EP
