Datasheet Texas Instruments SN54CBT16209 — Даташит
СерияSN54CBT16209
18-Bit Bus-Exchange Switch
SN54CBT16209, SN74CBT16209A datasheet
PDF, 760 Кб, Версия: O, Файл опубликован: 9 ноя 2004
LifeElectronics
SN54CBT16209WD
TradeElectronics
SN54CBT16209_07
ТаймЧипс
SN54CBT16209
Критерии выбора литиевых аккумуляторов и батареек: что необходимо учитывать разработчикам
5962-9669701QXASNJ54CBT16209WD
N12
Pin4848
Package TypeWDWD
Industry STD TermCFPCFP
JEDEC CodeR-GDFP-FR-GDFP-F
Package QTY11
CarrierTUBETUBE
Маркировка5962-9669701QXA
Width (мм)9.669.66
Length (мм)15.8815.88
Thickness (мм)2.482.48
Pitch (мм).635.635
Max Height (мм)3.053.05
Parameters / Models5962-9669701QXA
5962-9669701QXA
SNJ54CBT16209WD
SNJ54CBT16209WD
Количество каналов1818
Рабочий диапазон температур, Cот -55 до 125от -55 до 125
Package GroupCFPCFP
Package Size: mm2:W x L, PKGSee datasheet (CFP)See datasheet (CFP)
RatingMilitaryMilitary
Ron(Max), Ohms88
Ron(Typ), Ohms44
Technology FamilyCBTCBT
VCC(Max), В5.55.5
VCC(Min), В44
RoHSSee ti.comSee ti.com
  • How to Select Little Logic (Rev. A)
    PDF, 1.1 Мб, Версия: A, Файл опубликован: 26 июл 2016
    TI Little Logic devices are logic-gate devices assembled in a small single- dual- or triple- gate package. Little Logic devices are widely used in portable equipment such as mobile phones MP3 players and notebook computers. Little Logic devices also are used in desktop computers and telecommunications. Little Logic gates are common components for easy PC board routing schematic design and b
  • Flexible Voltage-Level Translation With CBT Family Devices
    PDF, 40 Кб, Файл опубликован: 20 июл 1999
    Voltage translation between buses with incompatible logic levels can be accomplished using Texas Instruments (TI) translation-voltage clamps (TVC) or standard crossbar technology (CBT) devices. CBT devices in this application offer flexibility in designs, protection of circuits that are sensitive to high-state voltage-level overshoots, and cost efficiency.
  • Selecting the Right Texas Instruments Signal Switch
    PDF, 769 Кб, Файл опубликован: 7 сен 2001
    Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi
  • Migration From 3.3-V To 2.5-V Power Supplies For Logic Devices
    PDF, 115 Кб, Файл опубликован: 1 дек 1997
    This application report explores the possibilities for migrating to 3.3-V and 2.5-V power supplies and discusses the implications.Customers are successfully using a wide range of low-voltage 3.3-V logic devices. These devices are within Texas Instruments (TI) advanced low-voltage CMOS (ALVC) crossbar technology (CBT) crossbar technology with integrated diode (CBTD) low-voltage crossbar techn
  • 5-V To 3.3-V Translation With the SN74CBTD3384 (Rev. B)
    PDF, 35 Кб, Версия: B, Файл опубликован: 1 мар 1997
    The emergence of low-voltage technology required existing 5-V systems to interact with 3.3-V systems. Compatibility issues of mixed-mode operation created the need for 5-V to 3.3-V translation. Buffers and transceivers serve as effective translators. While providing additional drive, these devices also add propagation delay and require directional control. In cases where additional drive is not
  • 3.3-V to 2.5-V Translation with Texas Instruments Crossbar Technology (Rev. A)
    PDF, 32 Кб, Версия: A, Файл опубликован: 3 апр 1998
  • Texas Instruments Little Logic Application Report
    PDF, 359 Кб, Файл опубликован: 1 ноя 2002
    Portable and consumer electronic systems? needs present greater challenges today than ever before. Engineers strive to design smaller faster lower-cost systems to meet the market demand. Consequently the semiconductor industry faces a growing need to increase operating speed minimize power consumption and reduce packaging size. Texas Instruments manufactures a variety of Little Logic semicond
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
Серия: SN54CBT16209 (2)
  • Semiconductors> Space & High Reliability> Logic Products> Switches and Multiplexer> Signal Switch
На английском языке: Datasheet Texas Instruments SN54CBT16209
