Datasheet Texas Instruments SN54LVTH162244-SP — Даташит
СерияSN54LVTH162244-SP
3.3.-V ABT 16-Bit Buffers/Drivers With 3-State Outputs
SN54LVTH162244; SN74LVTH162244 datasheet
PDF, 939 Кб, Версия: N, Файл опубликован: 1 ноя 2006
3.3-V ABT 16-BIT BUFFERS/DRIVERS WITH 3-STATE OUTPUTS
SN54LVTH162244_06
SN54LVTH162244
Электромеханические реле Hongfa – надежность и качество 19 января 2023
5962-9680901VXA
Статус продуктаВ производстве
5962-9680901VXA
N1
Pin48
Package TypeWD
Industry STD TermCFP
JEDEC CodeR-GDFP-F
Package QTY1
МаркировкаA
Width (мм)9.66
Length (мм)15.88
Thickness (мм)2.48
Pitch (мм).635
Max Height (мм)3.05
Parameters / Models5962-9680901VXA
5962-9680901VXA
Bits16
Тип входаTTL/CMOS
Рабочий диапазон температур, Cот -55 до 125
Тип выходаLVTTL
Package GroupCFP
Package Size: mm2:W x L, PKGSee datasheet (CFP)
RatingSpace
Schmitt TriggerNo
Technology FamilyLVT
VCC(Max), В3.6
VCC(Min), В2.7
Voltage(Nom), В3.3
5962-9680901VXA
RoHSSee ti.com
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • Live Insertion
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • Introduction to Logic
Серия: SN54LVTH162244-SP (1)
  • Semiconductors> Space & High Reliability> Logic Products> Buffers/Drivers/Transceivers> Buffer Drivers
На английском языке: Datasheet Texas Instruments SN54LVTH162244-SP
Публикации по теме
