Datasheet Texas Instruments SN54LVTH16244A-SP — Даташит
СерияSN54LVTH16244A-SP
3.3-V ABT 16-Bit Buffers/Drivers With 3-State Outputs
3.3-V ABT 16-BIT BUFFERS/DRIVERS WITH 3-STATE OUTPUTS, SNx4LVTH16244A datasheet
PDF, 968 Кб, Версия: U, Файл опубликован: 11 окт 2013
SN54LVTH16244A_09
Критерии выбора литиевых аккумуляторов и батареек: что необходимо учитывать разработчикам
5962-9668501VXA
Статус продуктаВ производстве
5962-9668501VXA
N1
Pin48
Package TypeWD
Industry STD TermCFP
JEDEC CodeR-GDFP-F
Package QTY1
Маркировка5962-9668501VX
Width (мм)9.66
Length (мм)15.88
Thickness (мм)2.48
Pitch (мм).635
Max Height (мм)3.05
Parameters / Models5962-9668501VXA
5962-9668501VXA
Bits16
Тип входаCMOS,TTL
Рабочий диапазон температур, Cот -55 до 125
Тип выходаLVTTL
Package GroupCFP
Package Size: mm2:W x L, PKGSee datasheet (CFP)
RatingSpace
Schmitt TriggerNo
Technology FamilyLVT
VCC(Max), В3.6
VCC(Min), В2.7
Voltage(Nom), В3.3
5962-9668501VXA
RoHSSee ti.com
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • Live Insertion
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • Introduction to Logic
Серия: SN54LVTH16244A-SP (1)
  • Semiconductors> Space & High Reliability> Logic Products> Buffers/Drivers/Transceivers> Buffer Drivers
На английском языке: Datasheet Texas Instruments SN54LVTH16244A-SP
Публикации по теме
