Datasheet Texas Instruments SN65HVD1050-Q1 — Даташит
Серия | SN65HVD1050-Q1 |
Automotive Catalog EMC Optimized CAN Transceiver
EMC-Optimized CAN Transceiver - SN65HVD1050-Q1 datasheet
PDF, 799 Кб, Версия: C, Файл опубликован: 20 дек 2010
EMC OPTIMIZED CAN TRANSCEIVER | |||
SN65HVD1050-Q1 Texas Instruments | по запросу | ||
SN65HVD1050-Q1 | по запросу |
SN65HVD1050QDRQ1 | |
Статус продукта | В производстве |
N | 1 |
Pin | 8 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | H1050Q |
Width (мм) | 3.91 |
Length (мм) | 4.9 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Parameters / Models | SN65HVD1050QDRQ1 |
Bus Fault Voltage, В | -27 to 40 |
Common Mode Voltage, В | -12 to 12 |
Основные особенности | High Speed,Vref Pin |
HBM ESD, kV | 4 |
IEC 61000-4-2 Contact, +/- kV | N/A |
Isolated | No |
Low Power Mode | Silent |
Рабочий диапазон температур, C | от -40 до 125 |
Package Group | SOIC |
Protocols | CAN |
Rating | Automotive |
Signaling Rate(Max), Mbps | 1 |
Supply Voltage(s), В | 4.75 to 5.25 |
- Common-Mode Chokes in CAN Networks: Source of Unexpected TransientsPDF, 230 Кб, Файл опубликован: 29 янв 2008
Common-mode chokes are frequently used in automotive CAN networks to increase system reliability with respect to electromagnetic compatibility (EMC). Electromagnetic interference emitted from an Electronic Control Module (ECU) through the CAN transceiver can be filtered, thus limiting unwanted high-frequency noise on the communication bus. Another reason for using a common-mode choke is attempting
Серия: SN65HVD1050-Q1 (1)
- Semiconductors> Interface> CAN Transceivers
