Datasheet Texas Instruments SN65HVD37 — Даташит
Серия | SN65HVD37 |
Low power 3.3 V Full-Duplex RS-485 Driver/Receiver
Low-Power 3.3V-Supply Full-Duplex RS-485 Driver/Receiver datasheet
PDF, 386 Кб, Версия: A, Файл опубликован: 29 ноя 2011
Купить SN65HVD37 на РадиоЛоцман.Цены — от 118 до 12 175 ₽ 26 предложений от 15 поставщиков TEXAS INSTRUMENTS SN65HVD37D RS485 Transceiver IC, Full Duplex, 1 Differential Driver, 3V to 3.6V, SOIC-14 | |||
SN65HVD37D Texas Instruments | от 118 ₽ | ||
SN65HVD37D Texas Instruments | 135 ₽ | ||
SN65HVD37D Texas Instruments | 243 ₽ | ||
SN65HVD37DR Texas Instruments | по запросу |
SN65HVD37D | SN65HVD37DR | |
Статус продукта | В производстве | В производстве |
Доступность образцов у производителя | Да | Да |
N | 1 | 2 |
Pin | 14 | 14 |
Package Type | D | D |
Industry STD Term | SOIC | SOIC |
Package QTY | 50 | 2500 |
Carrier | TUBE | LARGE T&R |
Маркировка | HVD37 | HVD37 |
Width (мм) | 3.91 | 3.91 |
Length (мм) | 8.65 | 8.65 |
Thickness (мм) | 1.58 | 1.58 |
Pitch (мм) | 1.27 | 1.27 |
Max Height (мм) | 1.75 | 1.75 |
Parameters / Models | SN65HVD37D | SN65HVD37DR |
Common Mode Range | -7 to 12 | -7 to 12 |
Duplex | Full | Full |
Fail Safe | Idle,Open,Short | Idle,Open,Short |
Fault Protection, В | -13 to 13 | -13 to 13 |
HBM ESD, kV | 15 | 15 |
ICC(Max), мА | 0.8 | 0.8 |
IEC 61000-4-2 Contact, +/- kV | N/A | N/A |
Isolated | No | No |
No. of RX | 1 | 1 |
No. of TX | 1 | 1 |
Number of Nodes | 256 | 256 |
Рабочий диапазон температур, C | от -40 до 85 | от -40 до 85 |
Package Group | SOIC | SOIC |
Rating | Catalog | Catalog |
Signaling Rate(Max), Mbps | 20 | 20 |
Supply Voltage(s)(Nom), В | 3.3 | 3.3 |
- Comparison of Differential-Mode Noise Immunity of RS-485 Recvrs W/3.3-V SupplyPDF, 1.0 Мб, Файл опубликован: 29 ноя 2011
RS-485 is a widely used standard for industrial communication due to its simplicity and suitability for use in high-noise environments on long cables. Inherent in the standard are balanced signal drivers and receivers, which use differential signaling to reject common-mode noise. Receiver hysteresis is commonly used to ensure glitch-free reception even when differential noise is present. This appl
Серия: SN65HVD37 (2)
- Semiconductors> Interface> RS-485 Transceivers
