Datasheet Texas Instruments SN65HVD54 — Даташит
Серия | SN65HVD54 |
High Output Full-duplex RS-485 Driver and Receiver with enables
High Output Full-Duplex RS-485 Drivers and Receivers datasheet
PDF, 1.2 Мб, Версия: E, Файл опубликован: 22 окт 2009
Купить SN65HVD54 на РадиоЛоцман.Цены — от 156 до 11 769 ₽ 20 предложений от 17 поставщиков RS-485 High Output Full-duplex RS-485 Driver and Receiver Single Transmitter/Receiver RS-422/RS-485 14Pin SOIC T/R | |||
SN65HVD54DR Texas Instruments | от 156 ₽ | ||
SN65HVD54DRG4 Texas Instruments | 177 ₽ | ||
SN65HVD54D Texas Instruments | по запросу | ||
SN65HVD54DRG4 Texas Instruments | по запросу |
SN65HVD54D | SN65HVD54DG4 | SN65HVD54DR | SN65HVD54DRG4 | |
Статус продукта | В производстве | В производстве | В производстве | В производстве |
Доступность образцов у производителя | Нет | Нет | Нет | Нет |
N | 1 | 2 | 3 | 4 |
Pin | 14 | 14 | 14 | 14 |
Package Type | D | D | D | D |
Industry STD Term | SOIC | SOIC | SOIC | SOIC |
JEDEC Code | R-PDSO-G | R-PDSO-G | R-PDSO-G | R-PDSO-G |
Package QTY | 50 | 50 | 2500 | 2500 |
Carrier | TUBE | TUBE | LARGE T&R | LARGE T&R |
Маркировка | 65HVD54 | 65HVD54 | 65HVD54 | 65HVD54 |
Width (мм) | 3.91 | 3.91 | 3.91 | 3.91 |
Length (мм) | 8.65 | 8.65 | 8.65 | 8.65 |
Thickness (мм) | 1.58 | 1.58 | 1.58 | 1.58 |
Pitch (мм) | 1.27 | 1.27 | 1.27 | 1.27 |
Max Height (мм) | 1.75 | 1.75 | 1.75 | 1.75 |
Mechanical Data | Скачать | Скачать | Скачать | Скачать |
Parameters / Models | SN65HVD54D | SN65HVD54DG4 | SN65HVD54DR | SN65HVD54DRG4 |
Common Mode Range | -7 to 12 | -7 to 12 | -7 to 12 | -7 to 12 |
Duplex | Full | Full | Full | Full |
Fail Safe | Idle,Open,Short | Idle,Open,Short | Idle,Open,Short | Idle,Open,Short |
Fault Protection, В | -9 to 14 | -9 to 14 | -9 to 14 | -9 to 14 |
HBM ESD, kV | 15 | 15 | 15 | 15 |
ICC(Max), мА | 8 | 8 | 8 | 8 |
IEC 61000-4-2 Contact, +/- kV | N/A | N/A | N/A | N/A |
Isolated | No | No | No | No |
No. of RX | 1 | 1 | 1 | 1 |
No. of TX | 1 | 1 | 1 | 1 |
Number of Nodes | 256 | 256 | 256 | 256 |
Рабочий диапазон температур, C | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Package Group | SOIC | SOIC | SOIC | SOIC |
Rating | Catalog | Catalog | Catalog | Catalog |
Signaling Rate(Max), Mbps | 5 | 5 | 5 | 5 |
Supply Voltage(s)(Nom), В | 5 | 5 | 5 | 5 |
RoHS | Совместим | Совместим | Совместим | Совместим |
Серия: SN65HVD54 (4)
- Semiconductors> Interface> RS-485 Transceivers
