Аналоги реле Phoenix Contact, Finder, Omron, ABB, Schneider
Datasheet Texas Instruments SN74ALVC16821 — Даташит
СерияSN74ALVC16821
3.3-V 20-Bit Bus-Interface Flip-Flop with 3-State Outputs
3.3-V 20-Bit Bus-Interface Flip-Flop With 3-State Outputs (Rev. A)
PDF, 186 Кб, Версия: A, Файл опубликован: 1 авг 1995
T-electron
SN74ALVC16821DLR
Электромеханические реле Hongfa – надежность и качество 19 января 2023
SN74ALVC16821DLSN74ALVC16821DLR
Статус продуктаСнят с производстваСнят с производства
N12
Pin5656
Package TypeDLDL
Industry STD TermSSOPSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Width (мм)7.497.49
Length (мм)18.4118.41
Thickness (мм)2.592.59
Pitch (мм).635.635
Max Height (мм)2.792.79
RoHSНе совместимНе совместим
Бессвинцовая технология (Pb Free)НетНет
  • TI SN74ALVC16835 Component Specification Analysis for PC100
    PDF, 43 Кб, Файл опубликован: 3 авг 1998
    The PC100 standard establishes design parameters for the PC SDRAM DIMM that is designed to operate at 100 MHz. The 168-pin, 8-byte, registered SDRAM DIMM is a JEDEC-defined device (JC-42.5-96-146A). Some of the defined signal paths include data signals, address signals, and control signals. This application report discusses the SN74ALVC16835 18-bit universal bus driver that is available from T
  • Logic Solutions for PC-100 SDRAM Registered DIMMs (Rev. A)
    PDF, 96 Кб, Версия: A, Файл опубликован: 13 май 1998
    Design of high-performance personal computer (PC) systems that are capable of meeting the needs imposed by modern operating systems and software includes the use of large banks of SDRAMs on DIMMs (see Figure 1).To meet the demands of stable functionality over the broad spectrum of operating environments, meet system timing needs, and to support data integrity, the loads presented by the large
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • Benefits & Issues of Migrating 5-V and 3.3-V Logic to Lower-Voltage Supplies (Rev. A)
    PDF, 154 Кб, Версия: A, Файл опубликован: 8 сен 1999
    In the last few years the trend toward reducing supply voltage (VCC) has continued as reflected in an additional specification of 2.5-V VCC for the AVC ALVT ALVC LVC LV and the CBTLV families.In this application report the different logic levels at VCC of 5 V 3.3 V 2.5 V and 1.8 V are compared. Within the report the possibilities for migration from 5-V logic and 3.3-V logic families
Серия: SN74ALVC16821 (2)
  • Semiconductors> Logic> Flip-Flop/Latch/Register> D-Type Flip-Flop
На английском языке: Datasheet Texas Instruments SN74ALVC16821
